TP Ceiling Microphone - Extension Kit Part Number
mohdshajan
Hi all,
Does anyone knows the Part Number for TP Ceiling Microphone Extension kit for ordering ?
Extension kit contents
  • 6 × Suspension cable, 680 mm, Ø = 1.5 mm
  • 6 × Suspension cable,1100 mm, Ø = 1.5 mm
  • 4 × Combined wood/metal screw,M6 × 80 mm
  • 8 × Hex nut, M6
  • 4 × Lock washer, M6
  • 4 × Eye bolt, M6 × 25 mm
  • 8 × Threaded rod, M6 × 75 mm
  • 12 × Threaded rod, M6 × 50 mm
  • 4 × Threaded tube, M6 × 42 mm, Ø 10 mm
  • 1 × Wood drill bit, 5 mm
  • 1 × Concrete drill bit, 6 mm
  • 4 × Concrete anchor, M6/40-95 A4
  • 1 × Loctite glue (not shown)
Enrico Conedera
The part number is CTS-MTKIT-UA=
Universal AudioScience Mounting Kit
