Custom Status Limit for Cisco Jabber Availability - Help
wgarvin01
I am using Cisco Jabber 11.8.0 Client and have come across a limit to the number of Custom Statuses allowed. It only allows for up to 3 Custom Statuses per the Main Status Types: Available, Away, and Do Not Disturb.
Is there a way to change this default limit on the number of Custom Statuses allowed?
Jaime Valencia
I don't believe that's something you can configure.
java
if this helps, please rate
