Directory issue in Jabber
VON CLAWSON
Level 3
Level 3
Directory issue in Jabber.
Jabber client version 11.6
Both windows and Mac
IM&P version 9.1
MRA is configured
So for MRA we have a multi domain setup.  we have the servicesDomain set to domain.int and the voiceservicesDomain set to uc.domain.com.  This is because we have our internal and external domains separate, not using split horizon.  My problem is when integrating with the directory.  I have manually put in contacts and used their internal address which is userid@domain.int.  However, after integrating with ldap when I search for users I see the manually created users with userid@domain.int and I also see the directory users with userid@uc.domain.com.  This is obviously using the userid@voiceservicesdomain. Presence is obviously not working on those.  If I set UseSIPURIToResolveContacts to true in the jabber-config.xml it will make the users in the directory userid@domain.com.  again, not what I am looking for.  I need to pull userid@domain.int from the directory or userid@servicesdomain.  What fields do I need to change in the jabber-config.xml to accomplish that.
Thanks for your help.
Please rate if this helps.
VON CLAWSON
Level 3
Level 3
Can anybody help me with this?
VON CLAWSON
Level 3
Level 3
Anyone?
