How to check CUCM DB and other Function whether still okay or not after unproper shutdown?
Ibrahim Jamil
Level 6
Level 6
Hello Guys
I experienced  a couple of power outage , my servers got unproper shutdown
how to check CUCM DB and other Function whether still okay or not???
thanks all
Anthony Holloway
Use RTMT to look at the Database status, you should see a value of 2 for each node. Alternatively, you can login to each node via SSH and run utils dbreplication runtimestate to look for that value of 2. I can't tell you which services to check, since this will vary per environment. I.e., CallManager might not be started on purpose if you have a dedicated Publisher with 1,500 or more devices in the cluster. However, generally speaking, if the service is Activated, it should be running.
