How to distribute WebEX with SCCM
I want to distribute Cisco Webex Meetings Desktop App version 39.3.0.582 via SCCM, but unfortunately I still get an update after the installation. I would like to turn this off. What are the possibilities?
I’ll like to use msiexec.exe /q /i "webexapp.msi" SITEURL="https://sample.webex.com" OI=1 OFFICE=1 IE=1 SKYPE=1 SAMETIME=1
And the parameters for these two items below.
Disable automatic updates, because it prompts the end-user before updating
Disable auto-start at logon
Jonathan Schulenberg
Please do not disable automatic updates! This is the #1 thing we’re trying to convince people to stop - so much of the user perception/reputation issues Webex has is because people run old versions of it. A lot of effort was put into making auto-update work without admin rights. Experience over the last six months has also taught us that frequent updates are necessary to keep the integration with Outlook functional as Microsoft themselves perform auto-update of the O365 apps. If memory serves it has broken three times for those not auto-updating. Yes, there is a prompt but the update completes even if the user does nothing; it’s just informational.
The mass deployment guide with all of the supported options is here:
https://www.cisco.com/c/dam/en/us/td/docs/collaboration/webex_centers/esp/webex_b_it-administrator-guide-mass-deployment-desktop-app.pdf
