How to start Jabber presence status by default (Offline)?
Gura24
is it possible to start Jabber presence status by default (Offline) ?
Thanks for help!
Cheers,
2 Accepted Solutions
Jaime Valencia
No, that is not possible.
java
if this helps, please rate
No for Instant messaging and Presence status you need IMP. Without IMP you can just configure the Jabber as phone mode which is basically a phone soft client like IP Communicator
Hope this helps
Cheers
Rath!
***Please rate helpful posts***
5 Replies 5
Jaime Valencia
java
Thx for quick response!
How I can disable presence function globally?
If you don't want to use IM&P then you should deploy Jabber in phone only mode.
java
I really want to use IMP and chat but without presence. Is it possible?
Cheers
Hope this helps
Cheers
Rath!
