Iphone jabber drops call after 19-20 seconds
link4voip
I start using jabber for iPhone but i have problme .
calls drops after 19-20 second
Please advice .
Regards ,
2 Accepted Solutions
Jorge Armijo
Level 4
Level 4
Great,
We are closer... If you notice, when doing "sh run" you have to press space bar a couple of times to get all the output... Once get all the sh run, we would be able to determine to what interface bound the SIP Traffic...
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Here it is:
voice service voip
sip
  bind control source-interface BVI100
  bind media source-interface BVI100
Jorge Armijo
28 Replies 28
Jorge Armijo
Level 4
Level 4
Is Jabber registered with CUCM or CME?
Is there audio on the first 19-20 seconds of call?
You may provide further details, so the community can help you with your problem.
Jorge Armijo
Here are the answers:
Is registered with CME
Yes everything is ok with the call when it reach´s 20 sec. the call drops.
What kind of details
Please take the following debugs:
deb ccsip all
deb voice ccapi inout
Provide the calling and called number and attach the output.
Please also attach the "show run" from the CME.
Jorge Armijo
Hi Eugenio,
Were you able to get the debugs from CME? I would like to check them and verify what's going on.
Jorge Armijo
In my case the issue have been solved by solution from this topic (at the bottom):
https://supportforums.cisco.com/thread/2153584
Good to hear that!
Jorge Armijo
HI Jorge
I made a debug in another thread that I made i hope you can help with this, tomorrow I will get the other one
https://supportforums.cisco.com/thread/2213262
That makes sense,
Go ahead and try adding bind commands for the interface that matches with the IP Address configured under "voice register global"
Jorge Armijo
HI
I put on:
  voice service voip
       sip
         bind all source-interface fastethernet 0/0
But all extensions went down.
That command was correct?
Hi Eugenio,
Is that the interface with IP Address you are using for "voice register global"?
Can you please share the "show run" from the CME?
Jorge Armijo
HI
I think is 10.1.1.1
Here is the show run:
Building configuration...
Current configuration : 40452 bytes
! Last configuration change at 10:35:40 CDT Tue May 7 2013 by PSCD
! NVRAM config last updated at 19:49:18 CDT Mon May 6 2013 by PSCD
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname PSCDTI
boot-start-marker
boot-end-marker
enable secret 4 a8Bb5HEutIH.A7Qk5HXDydsNHsvYyR.mPFH7Px.w8Rw
aaa new-model
aaa group server radius radius_local
server 192.168.10.1 auth-port 1812 acct-port 1813
aaa authentication login default local
aaa authentication login auth_method_radius_local group radius_local
aaa authentication login sdm_vpn_xauth_ml_1 local
aaa accounting update periodic 10
aaa accounting network acct_method_radius_local start-stop group radius_local
aaa session-id common
clock timezone CST -6 0
clock summer-time CDT recurring
crypto pki trustpoint TP-self-signed-3471476706
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3471476706
revocation-check none
rsakeypair TP-self-signed-3471476706
            quit
dot11 syslog
dot11 ssid PSCD TI
vlan 1
authentication open mac-address auth_method_radius_local
accounting acct_method_radius_local
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 192.168.10.1 192.168.10.10
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group Locales
max-retry 5
voice-class cause-code 1
hunt-scheme sequential
trunk group Nacional
max-retry 5
trunk group CEL
max-retry 5
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  registrar server expires max 1200 min 300
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
mode cme
source-address 10.1.1.1 port 5060
no outbound-proxy
max-dn 56
max-pool 14
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
load 3911 SIP3951.8-1-4a
authenticate register
timezone 8
date-format D/M/Y
hold-alert
voicemail 399
tftp-path flash:
create profile sync 0008170448582719
voice register dn  1
number 210
call-forward b2bua busy 399
call-forward b2bua noan 399 timeout 20
call-forward b2bua unregistered 399
name Eugenio Cortes
no-reg
label Eugenio Cortes
voice register dn  2
number 209
name Carlos Cajica
no-reg
label Carlos Cajica
voice register dn  3
number 200
name Recepcion
no-reg
label Recepcion
voice register dn  4
number 206
name Rosa Juana Puente
no-reg
label Rosa Juana Puente
voice register dn  5
number 211
name Veronica Cortes
no-reg
label Veronica Cortes
voice register dn  6
number 212
name Eliseo Palacios
no-reg
label Eliseo Palacios
voice register pool  1
registration-timer max 720 min 660
id mac 786C.1C8F.F4F5
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
dtmf-relay rtp-nte
username ecortes password 123456
codec g711ulaw
voice register pool  2
id mac 001A.A11B.9CD8
type 3911
number 1 dn 2
dtmf-relay rtp-nte
username ccajica password 123456
codec g711ulaw
voice register pool  3
id mac 001A.A11B.A062
type 3911
number 1 dn 3
dtmf-relay rtp-nte
username recepcion password 123456
codec g711ulaw
voice register pool  4
id mac 001A.A11B.9D6A
type 3911
number 1 dn 4
dtmf-relay rtp-nte
username rpuente password 123456
codec g711ulaw
voice register pool  5
id mac 001A.A11B.9D24
type 3911
number 1 dn 5
dtmf-relay rtp-nte
username vcortes password 123456
codec g711ulaw
voice register pool  6
id mac 001A.A11B.9CD0
type 3911
number 1 dn 6
dtmf-relay rtp-nte
username epalacios password 123456
codec g711ulaw
voice translation-rule 1000
rule 1 /.*/ //
voice translation-rule 1112
rule 1 /^9/ //
rule 2 /^4/ //
rule 3 /^1/ //
rule 4 /^7/ //
rule 5 /^8/ //
voice translation-rule 2001
voice translation-rule 2002
rule 1 /^6/ //
voice translation-rule 2222
voice translation-profile CALLER_ID_TRANSLATION_PROFILE
translate calling 1111
voice translation-profile CallBlocking
translate called 2222
voice translation-profile OUTGOING_TRANSLATION_PROFILE
translate called 1112
voice translation-profile XFER_TO_VM_PROFILE
translate redirect-called 2002
voice translation-profile nondialable
translate called 1000
voice-card 0
fax interface-type fax-mail
license udi pid UC520W-8U-4FXO-K9 sn FHK114251HV
archive
log config
  logging enable
  logging size 600
  hidekeys
process-max-time 150
ip tftp source-interface Loopback0
class-map match-all _class_Voice0
match ip dscp ef
class-map match-all _class_Voice1
match ip dscp cs3
policy-map Voice
class _class_Voice0
  set cos 6
class _class_Voice1
  set cos 3
bridge irb
interface Loopback0
description $FW_INSIDE$
ip address 10.1.10.2 255.255.255.252
ip access-group 101 in
ip nat inside
ip virtual-reassembly in
interface Loopback1
ip address 50.50.50.50 255.255.255.0
ip nat inside
interface FastEthernet0/0
description $FW_OUTSIDE$
ip address dhcp client-id FastEthernet0/0
ip access-group 104 in
ip nat outside
ip inspect SDM_LOW out
load-interval 30
duplex auto
speed auto
interface Integrated-Service-Engine0/0
description cue is initialized with default IMAP group
ip unnumbered Loopback0
ip nat inside
service-module ip address 10.1.10.1 255.255.255.252
service-module ip default-gateway 10.1.10.2
interface FastEthernet0/1/0
switchport voice vlan 100
no ip address
macro description cisco-phone
spanning-tree portfast
interface FastEthernet0/1/1
no ip address
interface FastEthernet0/1/2
no ip address
interface FastEthernet0/1/3
no ip address
interface FastEthernet0/1/4
no ip address
interface FastEthernet0/1/5
no ip address
interface FastEthernet0/1/6
no ip address
interface FastEthernet0/1/7
no ip address
interface FastEthernet0/1/8
switchport mode trunk
no ip address
macro description cisco-switch
interface Dot11Radio0/5/0
no ip address
ssid PSCD TI
ssid cisco-voice
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
antenna receive right
antenna transmit right
service-policy output Voice
interface Dot11Radio0/5/0.1
encapsulation dot1Q 1 native
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0/5/0.100
encapsulation dot1Q 100
bridge-group 100
bridge-group 100 subscriber-loop-control
bridge-group 100 spanning-disabled
bridge-group 100 block-unknown-source
no bridge-group 100 source-learning
no bridge-group 100 unicast-flooding
interface Virtual-Template1
ip unnumbered Loopback1
ip nat inside
interface Virtual-Template200 type serial
no ip address
interface Vlan1
no ip address
bridge-group 1
bridge-group 1 spanning-disabled
interface Vlan100
no ip address
bridge-group 100
interface BVI1
ip address 192.168.10.1 255.255.255.0
ip access-group 102 in
ip nat inside
interface BVI100
ip address 10.1.1.1 255.255.255.0
ip access-group 103 in
ip nat inside
ip local pool SDM_WEBVPN_POOL_1 192.168.10.150 192.168.10.162
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http path flash:/gui
ip dns server
ip nat inside source route-map SDM_RMAP_1 interface FastEthernet0/0 overload
ip route 10.1.10.1 255.255.255.255 Integrated-Service-Engine0/0
access-list 100 remark auto generated by SDM firewall configuration
access-list 100 remark SDM_ACL Category=1
access-list 100 deny   ip 192.168.10.0 0.0.0.255 any
access-list 100 deny   ip host 255.255.255.255 any
access-list 100 deny   ip 127.0.0.0 0.255.255.255 any
access-list 100 permit ip any any
access-list 101 remark auto generated by SDM firewall configuration
access-list 101 remark SDM_ACL Category=1
access-list 101 permit tcp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 permit udp 10.1.1.0 0.0.0.255 eq 2000 any
access-list 101 deny   ip 192.168.10.0 0.0.0.255 any
access-list 101 deny   ip 10.1.1.0 0.0.0.255 any
access-list 101 deny   ip host 255.255.255.255 any
access-list 101 deny   ip 127.0.0.0 0.255.255.255 any
access-list 101 permit ip any any
access-list 102 remark auto generated by SDM firewall configuration
access-list 102 remark SDM_ACL Category=1
access-list 102 deny   ip 10.1.10.0 0.0.0.3 any
access-list 102 deny   ip 10.1.1.0 0.0.0.255 any
access-list 102 deny   ip host 255.255.255.255 any
access-list 102 deny   ip 127.0.0.0 0.255.255.255 any
access-list 102 permit ip any any
access-list 103 remark auto generated by SDM firewall configuration
access-list 103 remark SDM_ACL Category=1
access-list 103 permit tcp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp 10.1.10.0 0.0.0.3 any eq 2000
access-list 103 permit udp any 10.1.10.0 0.0.0.3 range 16384 32767
access-list 103 permit udp 10.1.10.0 0.0.0.3 range 16384 32767 any
access-list 103 deny   ip 192.168.10.0 0.0.0.255 any
access-list 103 deny   ip host 255.255.255.255 any
access-list 103 deny   ip 127.0.0.0 0.255.255.255 any
access-list 103 permit ip any any
access-list 104 remark auto generated by SDM firewall configuration
access-list 104 remark SDM_ACL Category=1
access-list 104 permit tcp any host 10.12.127.1 eq 443
access-list 104 deny   ip 10.1.10.0 0.0.0.3 any
access-list 104 deny   ip 192.168.10.0 0.0.0.255 any
access-list 104 deny   ip 10.1.1.0 0.0.0.255 any
access-list 104 permit udp any eq bootps any eq bootpc
access-list 104 permit icmp any any echo-reply
access-list 104 permit icmp any any time-exceeded
access-list 104 permit icmp any any unreachable
access-list 104 deny   ip 10.0.0.0 0.255.255.255 any
access-list 104 deny   ip 172.16.0.0 0.15.255.255 any
access-list 104 deny   ip 192.168.0.0 0.0.255.255 any
access-list 104 deny   ip 127.0.0.0 0.255.255.255 any
access-list 104 deny   ip host 255.255.255.255 any
access-list 104 deny   ip any any
access-list 105 remark SDM_ACL Category=2
access-list 105 deny   ip any host 192.168.10.150
access-list 105 deny   ip any host 192.168.10.151
access-list 105 deny   ip any host 192.168.10.152
access-list 105 deny   ip any host 192.168.10.153
access-list 105 deny   ip any host 192.168.10.154
access-list 105 deny   ip any host 192.168.10.155
access-list 105 deny   ip any host 192.168.10.156
access-list 105 deny   ip any host 192.168.10.157
access-list 105 deny   ip any host 192.168.10.158
access-list 105 deny   ip any host 192.168.10.159
access-list 105 deny   ip any host 192.168.10.160
access-list 105 deny   ip any host 192.168.10.161
access-list 105 deny   ip any host 192.168.10.162
access-list 105 permit ip 10.1.10.0 0.0.0.3 any
access-list 105 permit ip 10.1.1.0 0.0.0.255 any
access-list 105 permit ip 192.168.10.0 0.0.0.255 any
route-map SDM_RMAP_1 permit 1
match ip address 105
snmp-server community public RO
tftp-server flash:/phones/521_524/cp524g-8-1-17.bin alias cp524g-8-1-17.bin
tftp-server flash:/phones/7906_7911/apps11.9-2-1TH1-13.sbn alias apps11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cnu11.9-2-1TH1-13.sbn alias cnu11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/cvm11sccp.9-2-1TH1-13.sbn alias cvm11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/dsp11.9-2-1TH1-13.sbn alias dsp11.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/jar11sccp.9-2-1TH1-13.sbn alias jar11sccp.9-2-1TH1-13.sbn
tftp-server flash:/phones/7906_7911/SCCP11.9-2-1S.loads alias SCCP11.9-2-1S.loads
tftp-server flash:/phones/7906_7911/term06.default.loads alias term06.default.loads
tftp-server flash:/phones/7906_7911/term11.default.loads alias term11.default.loads
tftp-server flash:/phones/7940_7960/P00308010200.bin alias P00308010200.bin
tftp-server flash:/phones/7940_7960/P00308010200.loads alias P00308010200.loads
tftp-server flash:/phones/7940_7960/P00308010200.sb2 alias P00308010200.sb2
tftp-server flash:/phones/7940_7960/P00308010200.sbn alias P00308010200.sbn
tftp-server flash:/phones/7941_7961/apps41.9-1-1TH1-16.sbn alias apps41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cnu41.9-1-1TH1-16.sbn alias cnu41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/cvm41sccp.9-1-1TH1-16.sbn alias cvm41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/dsp41.9-1-1TH1-16.sbn alias dsp41.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/jar41sccp.9-1-1TH1-16.sbn alias jar41sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7941_7961/SCCP41.9-1-1SR1S.loads alias SCCP41.9-1-1SR1S.loads
tftp-server flash:/phones/7941_7961/term41.default.loads alias term41.default.loads
tftp-server flash:/phones/7941_7961/term61.default.loads alias term61.default.loads
tftp-server flash:/phones/7942_7962/apps42.9-1-1TH1-16.sbn alias apps42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cnu42.9-1-1TH1-16.sbn alias cnu42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/cvm42sccp.9-1-1TH1-16.sbn alias cvm42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/dsp42.9-1-1TH1-16.sbn alias dsp42.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/jar42sccp.9-1-1TH1-16.sbn alias jar42sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7942_7962/SCCP42.9-1-1SR1S.loads alias SCCP42.9-1-1SR1S.loads
tftp-server flash:/phones/7942_7962/term42.default.loads alias term42.default.loads
tftp-server flash:/phones/7942_7962/term62.default.loads alias term62.default.loads
tftp-server flash:/phones/7945_7965/apps45.9-1-1TH1-16.sbn alias apps45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cnu45.9-1-1TH1-16.sbn alias cnu45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/cvm45sccp.9-1-1TH1-16.sbn alias cvm45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/dsp45.9-1-1TH1-16.sbn alias dsp45.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/jar45sccp.9-1-1TH1-16.sbn alias jar45sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7945_7965/SCCP45.9-1-1SR1S.loads alias SCCP45.9-1-1SR1S.loads
tftp-server flash:/phones/7945_7965/term45.default.loads alias term45.default.loads
tftp-server flash:/phones/7945_7965/term65.default.loads alias term65.default.loads
tftp-server flash:/phones/7970_7971/apps70.9-1-1TH1-16.sbn alias apps70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cnu70.9-1-1TH1-16.sbn alias cnu70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/cvm70sccp.9-1-1TH1-16.sbn alias cvm70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/dsp70.9-1-1TH1-16.sbn alias dsp70.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/jar70sccp.9-1-1TH1-16.sbn alias jar70sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7970_7971/SCCP70.9-1-1SR1S.loads alias SCCP70.9-1-1SR1S.loads
tftp-server flash:/phones/7970_7971/term70.default.loads alias term70.default.loads
tftp-server flash:/phones/7970_7971/term71.default.loads alias term71.default.loads
tftp-server flash:/phones/7975/apps75.9-1-1TH1-16.sbn alias apps75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cnu75.9-1-1TH1-16.sbn alias cnu75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/cvm75sccp.9-1-1TH1-16.sbn alias cvm75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/dsp75.9-1-1TH1-16.sbn alias dsp75.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/jar75sccp.9-1-1TH1-16.sbn alias jar75sccp.9-1-1TH1-16.sbn
tftp-server flash:/phones/7975/SCCP75.9-1-1SR1S.loads alias SCCP75.9-1-1SR1S.loads
tftp-server flash:/phones/7975/term75.default.loads alias term75.default.loads
tftp-server flash:/ringtones/Analog1.raw alias Analog1.raw
tftp-server flash:/ringtones/Analog2.raw alias Analog2.raw
tftp-server flash:/ringtones/AreYouThere.raw alias AreYouThere.raw
tftp-server flash:/ringtones/DistinctiveRingList.xml alias DistinctiveRingList.xml
tftp-server flash:/ringtones/RingList.xml alias RingList.xml
tftp-server flash:/ringtones/AreYouThereF.raw alias AreYouThereF.raw
tftp-server flash:/ringtones/Bass.raw alias Bass.raw
tftp-server flash:/ringtones/CallBack.raw alias CallBack.raw
tftp-server flash:/ringtones/Chime.raw alias Chime.raw
tftp-server flash:/ringtones/Classic1.raw alias Classic1.raw
tftp-server flash:/ringtones/Classic2.raw alias Classic2.raw
tftp-server flash:/ringtones/ClockShop.raw alias ClockShop.raw
tftp-server flash:/ringtones/Drums1.raw alias Drums1.raw
tftp-server flash:/ringtones/Drums2.raw alias Drums2.raw
tftp-server flash:/ringtones/FilmScore.raw alias FilmScore.raw
tftp-server flash:/ringtones/HarpSynth.raw alias HarpSynth.raw
tftp-server flash:/ringtones/Jamaica.raw alias Jamaica.raw
tftp-server flash:/ringtones/KotoEffect.raw alias KotoEffect.raw
tftp-server flash:/ringtones/MusicBox.raw alias MusicBox.raw
tftp-server flash:/ringtones/Piano1.raw alias Piano1.raw
tftp-server flash:/ringtones/Piano2.raw alias Piano2.raw
tftp-server flash:/ringtones/Pop.raw alias Pop.raw
tftp-server flash:/ringtones/Pulse1.raw alias Pulse1.raw
tftp-server flash:/ringtones/Ring1.raw alias Ring1.raw
tftp-server flash:/ringtones/Ring2.raw alias Ring2.raw
tftp-server flash:/ringtones/Ring3.raw alias Ring3.raw
tftp-server flash:/ringtones/Ring4.raw alias Ring4.raw
tftp-server flash:/ringtones/Ring5.raw alias Ring5.raw
tftp-server flash:/ringtones/Ring6.raw alias Ring6.raw
tftp-server flash:/ringtones/Ring7.raw alias Ring7.raw
tftp-server flash:/ringtones/Sax1.raw alias Sax1.raw
tftp-server flash:/ringtones/Sax2.raw alias Sax2.raw
tftp-server flash:/ringtones/Vibe.raw alias Vibe.raw
tftp-server flash:/Desktops/CampusNight.png
tftp-server flash:/Desktops/TN-CampusNight.png
tftp-server flash:/Desktops/CiscoFountain.png
tftp-server flash:/Desktops/TN-CiscoFountain.png
tftp-server flash:/Desktops/CiscoLogo.png
tftp-server flash:/Desktops/TN-CiscoLogo.png
tftp-server flash:/Desktops/Fountain.png
tftp-server flash:/Desktops/TN-Fountain.png
tftp-server flash:/Desktops/MorroRock.png
tftp-server flash:/Desktops/TN-MorroRock.png
tftp-server flash:/Desktops/NantucketFlowers.png
tftp-server flash:/Desktops/TN-NantucketFlowers.png
tftp-server flash:Desktops/320x212x16/List.xml
tftp-server flash:Desktops/320x212x12/List.xml
tftp-server flash:Desktops/320x216x16/List.xml
tftp-server flash:/bacdprompts/en_bacd_allagentsbusy.au alias en_bacd_allagentsbusy.au
tftp-server flash:/bacdprompts/en_bacd_disconnect.au alias en_bacd_disconnect.au
tftp-server flash:/bacdprompts/en_bacd_enter_dest.au alias en_bacd_enter_dest.au
tftp-server flash:/bacdprompts/en_bacd_invalidoption.au alias en_bacd_invalidoption.au
tftp-server flash:/bacdprompts/en_bacd_music_on_hold.au alias en_bacd_music_on_hold.au
tftp-server flash:/bacdprompts/en_bacd_options_menu.au alias en_bacd_options_menu.au
tftp-server flash:/bacdprompts/en_bacd_welcome.au alias en_bacd_welcome.au
tftp-server flash:/bacdprompts/en_bacd_xferto_operator.au alias en_bacd_xferto_operator.au
tftp-server flash:/phones/3900/BOOT3951.0-0-0-9.zz alias BOOT3951.0-0-0-9.zz
tftp-server flash:/phones/3900/DSP3951.0-0-0-2.zz alias DSP3951.0-0-0-2.zz
tftp-server flash:/phones/3900/SIP3951.8-1-4a.loads alias SIP3951.8-1-4a.loads
tftp-server flash:/phones/3900/SIP3951.8-1-4a.zz alias SIP3951.8-1-4a.zz
radius-server local
radius-server attribute 32 include-in-access-req format %h
radius-server attribute 31 send nas-port-detail
radius-server host 192.168.10.1 auth-port 1812 acct-port 1813 key p5cd15acv
control-plane
bridge 1 route ip
bridge 100 route ip
voice-port 0/0/0
cptone MX
station-id number 401
caller-id enable
voice-port 0/0/1
cptone MX
station-id number 402
caller-id enable
voice-port 0/0/2
cptone MX
station-id number 403
caller-id enable
voice-port 0/0/3
cptone MX
station-id number 404
caller-id enable
voice-port 0/1/0
cptone MX
connection plar opx 398
description Configured by CCA 4 FXO-0/1/0-AA
caller-id enable
voice-port 0/1/1
cptone MX
description Configured by CCA 4 FXO-0/1/1-AA
caller-id enable
voice-port 0/1/2
trunk-group CEL 64
cptone MX
description Configured by CCA 4 FXO-0/1/2-AA
caller-id enable
voice-port 0/1/3
trunk-group CEL 63
cptone MX
description Configured by CCA 4 FXO-0/1/3-AA
caller-id enable
voice-port 0/2/0
trunk-group Nacional 63
cptone MX
description Configured by CCA 4 FXO-0/2/0-AA
caller-id enable
voice-port 0/2/1
trunk-group Nacional 64
cptone MX
description Configured by CCA 4 FXO-0/2/1-AA
caller-id enable
voice-port 0/2/2
trunk-group Locales 64
cptone MX
description Configured by CCA 4 FXO-0/2/2-AA
caller-id enable
voice-port 0/2/3
trunk-group Locales 63
cptone MX
description Configured by CCA 4 FXO-0/2/3-AA
caller-id enable
voice-port 0/4/0
auto-cut-through
signal immediate
input gain auto-control -15
description Music On Hold Port
sccp local Loopback0
sccp ccm 10.1.1.1 identifier 1 version 3.1
sccp
sccp ccm group 1
associate ccm 1 priority 1
dial-peer cor custom
name internal
name local
name local-plus
name international
name national
name national-plus
name emergency
name toll-free
dial-peer cor list call-internal
member internal
dial-peer cor list call-local
member local
dial-peer cor list call-local-plus
member local-plus
dial-peer cor list call-national
member national
dial-peer cor list call-national-plus
member national-plus
dial-peer cor list call-international
member international
dial-peer cor list call-emergency
member emergency
dial-peer cor list call-toll-free
member toll-free
dial-peer cor list user-internal
member internal
member emergency
dial-peer cor list user-local
member internal
member local
member emergency
member toll-free
dial-peer cor list user-local-plus
member internal
member local
member local-plus
member emergency
member toll-free
dial-peer cor list user-national
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-national-plus
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer cor list user-international
member internal
member local
member local-plus
member national
member emergency
member toll-free
dial-peer voice 1 pots
destination-pattern 401
port 0/0/0
no sip-register
dial-peer voice 2 pots
destination-pattern 402
port 0/0/1
no sip-register
dial-peer voice 3 pots
destination-pattern 403
port 0/0/2
no sip-register
dial-peer voice 4 pots
destination-pattern 404
port 0/0/3
no sip-register
dial-peer voice 5 pots
description ** MOH Port **
destination-pattern ABC
port 0/4/0
no sip-register
dial-peer voice 6 pots
description ôcatch all dial peer for BRI/PRIö
translation-profile incoming nondialable
incoming called-number .%
direct-inward-dial
dial-peer voice 50 pots
description ** incoming dial peer **
incoming called-number ^AAAA$
port 0/1/0
dial-peer voice 51 pots
port 0/1/1
dial-peer voice 52 pots
port 0/1/2
dial-peer voice 53 pots
port 0/1/3
dial-peer voice 100 pots
port 0/2/0
dial-peer voice 101 pots
port 0/2/1
dial-peer voice 102 pots
port 0/2/2
dial-peer voice 103 pots
port 0/2/3
dial-peer voice 54 pots
description ** FXO pots dial-peer **
destination-pattern A0
port 0/1/0
no sip-register
dial-peer voice 55 pots
destination-pattern A1
port 0/1/1
no sip-register
dial-peer voice 56 pots
destination-pattern A2
port 0/1/2
no sip-register
dial-peer voice 57 pots
destination-pattern A3
port 0/1/3
no sip-register
dial-peer voice 104 pots
destination-pattern A4
port 0/2/0
no sip-register
dial-peer voice 105 pots
destination-pattern A5
port 0/2/1
no sip-register
dial-peer voice 106 pots
destination-pattern A6
port 0/2/2
no sip-register
dial-peer voice 107 pots
destination-pattern A7
port 0/2/3
no sip-register
dial-peer voice 2000 voip
description ** cue voicemail pilot number **
translation-profile outgoing XFER_TO_VM_PROFILE
destination-pattern 399
b2bua
session protocol sipv2
session target ipv4:10.1.10.1
voice-class sip outbound-proxy ipv4:10.1.10.1
dtmf-relay sip-notify
codec g711ulaw
no vad
dial-peer voice 2001 voip
description ** cue auto attendant number **
translation-profile outgoing PSTN_CallForwarding
destination-pattern 398
b2bua
codec g711ulaw
no vad
dial-peer voice 2012 voip
description ** cue prompt manager number **
destination-pattern 397
b2bua
codec g711ulaw
no vad
dial-peer voice 65 pots
trunkgroup Locales
corlist outgoing call-local
description **CCA*Mexico*Local Calls - 7, 8 or 10 digits depending on loca**
translation-profile outgoing OUTGOING_TRANSLATION_PROFILE
preference 5
destination-pattern 1[1-9]T
forward-digits all
no sip-register
dial-peer voice 69 pots
trunkgroup CEL
corlist outgoing call-local-plus
description **CCA*Mexico*Mobile Numbers**
preference 5
destination-pattern 4[1-9]T
forward-digits all
no sip-register
dial-peer voice 70 pots
trunkgroup Nacional
corlist outgoing call-international
description **CCA*Mexico*International Calls**
preference 5
destination-pattern 700T
forward-digits all
no sip-register
dial-peer voice 63 pots
trunkgroup Locales
preference 5
forward-digits all
no sip-register
dial-peer voice 71 pots
trunkgroup CEL
preference 5
forward-digits all
no sip-register
dial-peer voice 73 pots
trunkgroup CEL
corlist outgoing call-emergency
description **CCA*Mexico*Emergency**
preference 5
destination-pattern 8060
forward-digits all
no sip-register
dial-peer voice 58 pots
trunkgroup Locales
preference 5
forward-digits all
no sip-register
dial-peer voice 72 pots
trunkgroup Nacional
preference 5
forward-digits all
no sip-register
dial-peer voice 75 pots
trunkgroup CEL
preference 5
destination-pattern 060
forward-digits all
no sip-register
dial-peer voice 74 pots
trunkgroup Nacional
preference 5
forward-digits all
no sip-register
dial-peer voice 61 pots
trunkgroup Locales
preference 5
forward-digits all
no sip-register
dial-peer voice 76 pots
trunkgroup Nacional
corlist outgoing call-national
description **CCA*Mexico*LADA**
preference 5
destination-pattern 901T
forward-digits all
no sip-register
no dial-peer outbound status-check pots
presence
presence call-list
sip-ua
mwi-server ipv4:10.1.10.1 expires 120 port 5060 transport udp
presence enable
telephony-service
video
fxo hook-flash
max-ephones 14
max-dn 56
ip source-address 10.1.1.1 port 2000
auto assign 1 to 1 type bri
calling-number initiator
service phone videoCapability 1
service phone ehookenable 1
service dnis overlay
service dnis dir-lookup
service dss
timeouts interdigit 5
system message PSCD TI SA de CV
url services http://10.1.10.1/voiceview/common/login.do
url authentication http://10.1.10.1/voiceview/authentication/authenticate.do
load 7906 SCCP11.9-2-1S
load 7911 SCCP11.9-2-1S
load 7960-7940 P00308010200
load 7941 SCCP41.9-1-1SR1S
load 7941GE SCCP41.9-1-1SR1S
load 7942 SCCP42.9-1-1SR1S
load 7945 SCCP45.9-1-1SR1S
load 7961 SCCP41.9-1-1SR1S
load 7961GE SCCP41.9-1-1SR1S
load 7962 SCCP42.9-1-1SR1S
load 7965 SCCP45.9-1-1SR1S
load 7970 SCCP70.9-1-1SR1S
load 7971 SCCP70.9-1-1SR1S
load 7975 SCCP75.9-1-1SR1S
load 521G-524G cp524g-8-1-17
time-zone 8
date-format dd-mm-yy
keepalive 30 auxiliary 4
voicemail 399
max-conferences 8 gain -6
call-forward pattern .T
call-forward system redirecting-expanded
moh flash:/media/music-on-hold.au
multicast moh 239.10.16.16 port 2000
web admin system name cisco secret 5 $1$LueE$BYPOgzzgSJk4ep/WZBDMN0
dn-webedit
time-webedit
transfer-system full-consult dss
transfer-pattern 9.T
transfer-pattern .T
transfer-pattern 6... blind
secondary-dialtone 9
night-service day Sun 17:00 09:00
night-service day Mon 17:00 09:00
night-service day Tue 17:00 09:00
night-service day Wed 17:00 09:00
night-service day Thu 17:00 09:00
night-service day Fri 17:00 09:00
night-service day Sat 17:00 09:00
fac standard
create cnf-files version-stamp 7960 May 06 2013 18:06:42
ephone-template  15
url services 1 http://10.1.10.1/voiceview/common/login.do VoiceviewExpress
softkeys remote-in-use  Newcall
softkeys idle  Redial Newcall Cfwdall Pickup Gpickup Dnd Login
softkeys seized  Cfwdall Endcall Redial Pickup Gpickup Callback
softkeys connected  Hold Endcall Trnsfer TrnsfVM Confrn Acct Park
button-layout 7931 2
ephone-template  16
ephone-template  17
softkeys remote-in-use  CBarge Newcall
ephone-template  18
ephone-dn  9
number BCD no-reg primary
description MoH
moh out-call ABC
ephone-dn  47  dual-line
number 208 no-reg primary
label 208
description Adriana Rojas
name Adriana Rojas
call-forward busy 399
call-forward noan 399 timeout 20
ephone-dn  48  dual-line
number 207 no-reg primary
label 207
description Carolina Cabildo
name Carolina Cabildo
ephone-dn  49  dual-line
number 205 no-reg primary
label 205
description Raul Faisal
name Raul Faisal
ephone-dn  50  dual-line
number 204 no-reg primary
label 204
description Leonardo Mendoza
name Leonardo Mendoza
ephone-dn  51  dual-line
number 203 no-reg primary
label 203
description Gerardo Guzman
name Gerardo Guzman
ephone-dn  52  dual-line
number 202 no-reg primary
label 202
description Blanca Calderon
name Blanca Calderon
ephone-dn  53  dual-line
number 201 no-reg primary
label 201
description Pilar Infante
name Pilar Infante
ephone-dn  54
number 6... no-reg primary
description ***CCA XFER TO VM EXTENSION***
call-forward all 399
ephone-dn  55
number A801... no-reg primary
mwi off
ephone-dn  56
number A800... no-reg primary
mwi on
ephone  5
device-security-mode none
mac-address 0022.555E.A09A
ephone-template 16
username "GGuzman" password 123456
type 7965
button  1:51
ephone  6
mac-address 001C.58FB.B1AB
ephone-template 16
username "PInfante" password 123456
type 7940
button  1:53
ephone  7
mac-address 0023.5EB6.9E24
ephone-template 16
username "BCalderon" password 123456
type 7911
button  1:52
ephone  8
mac-address 0023.5EB7.CD26
ephone-template 16
username "ARojas" password 123456
type 7911
button  1:47
ephone  9
mac-address 0021.D8B9.1598
ephone-template 16
username "RFaisal" password 123456
type 7975
button  1:49
ephone  10
mac-address 0022.555E.A01B
ephone-template 16
username "LMendoza" password 123456
type 7965
button  1:50
ephone  11
mac-address 0023.0434.0453
ephone-template 16
username "CCabildo" password 123456
type 7970
button  1:48
ephone-hunt 1 sequential
pilot 501
list 208
final 206
timeout 8
no-reg pilot
statistics collect
description ACP
alias exec cca_voice_mode PBX
banner login ^Cbanner login ^Cisco Configuration Assistant. Version: 3.2 (2). Mon May 06 17:50:06 CDT 2013^^C
line con 0
no modem enable
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport input all
line vty 0 4
transport input all
line vty 5 100
transport input all
ntp master
webvpn gateway SDM_WEBVPN_GATEWAY_1
ip address 10.12.127.1 port 443
ssl trustpoint TP-self-signed-3471476706
inservice
webvpn install svc flash:/webvpn/anyconnect-win-2.5.3055-k9.pkg sequence 1
webvpn context SDM_WEBVPN_CONTEXT_1
secondary-color white
title-color #CCCC66
text-color black
ssl authenticate verify all
policy group SDM_WEBVPN_POLICY_1
   functions svc-enabled
   svc address-pool "SDM_WEBVPN_POOL_1" netmask 255.255.255.0
   svc keep-client-installed
virtual-template 1
default-group-policy SDM_WEBVPN_POLICY_1
aaa authentication list sdm_vpn_xauth_ml_1
max-users 10
inservice
end
IP Address 10.1.1.1 under "voice register global" is configured on "interface BVI100", hence you may try to bind the SIP traffic to that interface.
Jorge Armijo
It work, I just need to tested in 3G and telephone integration.
Hi Eugenio,
Glad to hear that, please remember to rate helpful responses and identify helpful or correct answers.
Jorge Armijo
