Iphone jabber drops call after 19-20 seconds
link4voip
I start using jabber for iPhone but i have problme .
calls drops after 19-20 second
Please advice .
Regards ,
28 Replies 28
Thanks for every body to help in this case but really i am not professional in cisco and i need some one to access by team viewer and help me to solve the problme since the call is still drop every 19-20 second .
Regards ,
Hi Mohammed,
If you could post the "show run" from your CME we could help even more... Not all the time we are able to provide remote support, since we alredy spend our day providing remote support.
At the end, if you can't get this, we can schedule a remote session.
Jorge Armijo
Please remember to rate helpful responses and identify helpful or correct answers.
-- Jorge Armijo Please remember to rate helpful responses and identify helpful or correct answers.
Thanks for your quick response
I dont know how to do show run
I use the CCA setup wizard to configure the UC540 and i really i dont have good experciance with cisco .
Can you just open a SSH/TELNET client and using the Router IP Address to open a connection?
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_example09186a0080204528.shtml
Once you're in, is much easier.
Jorge Armijo
banner login ^Cisco Configuration Assistant. Version: 3.2 (2). Sun May  05 18:17:03 AST 2013^Using keyboard-interactive authentication.
Password:
UC_540>show run
% Invalid input detected at '^' marker.
UC_540>
Jorge Armijo
Level 4
Level 4
Do "enable" and try "sh run"
I get long text and i cant copied all
Current configuration : 41384 bytes
! Last configuration change at 04:23:13 PST Thu May 9 2013 by link4voip
! NVRAM config last updated at 02:04:55 PST Thu May 9 2013
version 15.1
parser config cache interface
no service pad
service internal
service compress-config
service sequence-numbers
hostname UC_540
boot-start-marker
boot-end-marker
enable secret 4 P8JE6vEs/KJGC42kJLwzbDqA/HfmsayTXRoCT6/KF0E
aaa new-model
aaa authentication login default local
aaa session-id common
clock timezone MSK 3 0
clock summer-time PST recurring
crypto pki trustpoint TP-self-signed-435213020
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-435213020
revocation-check none
rsakeypair TP-self-signed-435213020
crypto pki certificate chain TP-self-signed-435213020
certificate self-signed 01
  30820229 30820192 A0030201 02020101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 34333532 31333032 30301E17 0D313330 35303530 34333833
  325A170D 32303031 30313030 30303030 5A303031 2E302C06 03550403 1325494F
  532D5365 6C662D53 69676E65 642D4365 72746966 69636174 652D3433 35323133
  30323030 819F300D 06092A86 4886F70D 01010105 0003818D 00308189 02818100
  C50A8FA0 01624E3B 58D6119A F071D9B7 38D8D1E0 F79B7940 D2B0F27A 0D51A7F1
  8E5BEB22 156ED0FB DCC0560A B10D487F 6BC9FD84 9BB0ED01 DB269386 BEED0BB3
  4377A4A5 6A83543B 20ECA29A 72B76E4D 57E1F402 3580130E DB50A168 7F4103FF
  1F1F52E0 15897DE6 84F0CAF9 050CB387 CF3184F8 57D7D365 BF023A62 140F1C8F
  02030100 01A35330 51300F06 03551D13 0101FF04 05300301 01FF301F 0603551D
  23041830 16801471 61557232 5E3BC666 40E3EFE6 EDF97AC9 0970C530 1D060355
  1D0E0416 04147161 5572325E 3BC66640 E3EFE6ED F97AC909 70C5300D 06092A86
  4886F70D 01010505 00038181 003FEDC6 2DD2FFAC 43F77E4F F76A1D3B 6F5DE681
  37E7C557 34AA00EF 88BC6FC0 37B001F3 34FF84DB 8A5D6955 DEEBAE8B FB2DBADE
  EF3AAF04 AC1F5495 8ABF7DFE 368BAD10 59301918 ED472EFA 83659125 4F119095
  4729FB25 DA88D097 2F4749AB 3A27E22F 4C86D76A 2BB1D029 41522671 B11924EF
  D5E08A7B 49A12052 0D43CD13 32
        quit
dot11 syslog
dot11 ssid cisco-data
vlan 1
authentication open
dot11 ssid cisco-voice
vlan 100
authentication open
ip source-route
ip cef
ip dhcp relay information trust-all
ip dhcp excluded-address 10.1.1.1 10.1.1.9
ip dhcp excluded-address 10.1.1.241 10.1.1.255
ip dhcp excluded-address 192.168.10.1 192.168.10.9
ip dhcp excluded-address 192.168.10.241 192.168.10.255
ip dhcp pool phone
network 10.1.1.0 255.255.255.0
default-router 10.1.1.1
option 150 ip 10.1.1.1
ip dhcp pool data
import all
network 192.168.10.0 255.255.255.0
default-router 192.168.10.1
ip inspect WAAS flush-timeout 10
ip inspect name SDM_LOW dns
ip inspect name SDM_LOW ftp
ip inspect name SDM_LOW h323
ip inspect name SDM_LOW https
ip inspect name SDM_LOW icmp
ip inspect name SDM_LOW imap
ip inspect name SDM_LOW pop3
ip inspect name SDM_LOW netshow
ip inspect name SDM_LOW rcmd
ip inspect name SDM_LOW realaudio
ip inspect name SDM_LOW rtsp
ip inspect name SDM_LOW esmtp
ip inspect name SDM_LOW sqlnet
ip inspect name SDM_LOW streamworks
ip inspect name SDM_LOW tftp
ip inspect name SDM_LOW tcp router-traffic
ip inspect name SDM_LOW udp router-traffic
ip inspect name SDM_LOW vdolive
no ipv6 cef
stcapp ccm-group 1
stcapp
trunk group ALL_FXO
max-retry 5
voice-class cause-code 1
hunt-scheme longest-idle
voice call send-alert
voice rtp send-recv
voice service voip
allow-connections h323 to sip
allow-connections sip to h323
allow-connections sip to sip
supplementary-service h450.12
sip
  registrar server expires max 600 min 60
  no update-callerid
voice class codec 1
codec preference 1 g711ulaw
codec preference 2 g729r8
voice class cause-code 1
no-circuit
voice register global
mode cme
source-address 10.1.1.1 port 5060
no outbound-proxy
max-dn 56
max-pool 14
load 9971 sip9971.9-2-2
load 9951 sip9951.9-2-2
load 8961 sip8961.9-2-2
authenticate register
timezone 32
hold-alert
voicemail 399
tftp-path flash:
create profile sync 0093375432021472
voice register dn  1
number 222
name Mohd iPhone
no-reg
label 222
voice register pool  1
registration-timer max 720 min 660
id mac 6896.7B0F.EE0E
session-transport tcp
type CiscoMobile-iOS
number 1 dn 1
--More--
Jorge Armijo
Level 4
Level 4
Great,
We are closer... If you notice, when doing "sh run" you have to press space bar a couple of times to get all the output... Once get all the sh run, we would be able to determine to what interface bound the SIP Traffic...
Here it is:
voice service voip
sip
  bind control source-interface BVI100
  bind media source-interface BVI100
Jorge Armijo
one problem come up
before we run the command there was ext. 222 for iphone and 220 for 7921g
now when i try to call this ext. from any another IP phone its ringing but when try to dial the ext. by auto attendant its saying : you have entered in invalid phone number !
Update : After few hours of trying i found when i enable the voice mail for this ext's its start accepting calls by auto attendant and when i disable voice mail i gety ou have entered in invalid phone number !
can you pleae advice ?
problem solved , many thanks for the professional work
god bless you
Im having the same problem when someone calls and when they try to dial an extension or number option in the auto attendant it doesn´t work also when I call to a number and i try to dial options or extension it doesnt do anything.
What happens if you call to a non jabber extension?
Please make sure that the SIP Gateway on CUE matches the IP Address of the bound interface on CME.
Jorge Armijo
It does the same, when someone calls the autoattendat runs ok but when they try to choose an option it doesn´t do anything autoattendan keeps going.
