Is there any way to automatically forward all calls to voicemail when I select a Red "Do Not Disturb" presence?
domneu
New installation of a BE6000S here.  My users got very used to a DND "Do Not Disturb" button on our old phones.  It basically prevented the phone from ringing and sent everything to voicemail.  I would like to do that here.  I realize I can select Do Not Disturb and forward all calls to voicemail with two clicks, but they would like it in one click, or even a button on the phone.  Is this even possible?
domneu
Jaime Valencia
Not in Jabber, DND settings are under sounds and alerts and that's all you get to configure.
Not even on the phone you can set a CFA behavior with a single button, you would need at least two, CFA + speed dial.
java
if this helps, please rate
Jaime Valencia
java
