Issue/Feature request of Spark
yupeng
1, When I create a meeting in a room. The CPU usage is quite high in my MBP 13"
2. I wonder whether there is way to use Cisco physical phone/TP endpoint to join the room.
skilambi
2) Use Proximity, you can move the call between Spark on mobile and the endpoint like TP. In the past Cisco would publish the room URI but now it's not easily advertised so you cannot easily dial that URI.
Hi, Srinivasan,
Thanks for your reply.
I walked into a room with DX80, but the proximity doesn't connect.
I want more to see any solution for normal Cisco phone such as 9951. As the 1) issue, I'd like to have a physical one to offload my CPU utilization.
David
I haven't tested proximity with DX on spark cloud but it does work with SX10N
