J4W 10.6 / Disable Remote Control Desktop
n-coutant
When the Screen sharing is enable, the Remote Control Desktop is also available.
Is it possible to disable only the Remote Control Desktop feature ?
Thanks.
Nicolas
Manish Gogna
Hi Nicolas,
An enhancement is open to track this
https://tools.cisco.com/bugsearch/bug/CSCur02886/?referring_site=bugquickviewclick
J4W Disable Remote Desktop Control,Allow only screen share
CSCur02886
Symptom:
Feature request to disable Remote Desktop Control but allow only screen share
Conditions:
Jabber for Windows 10.5
It might be available in one of the future releases.
Manish
Manish Gogna
Hi Nicolas,
CSCur02886
Symptom:
Conditions:
Manish
Thanks Manish.
I hope this bug will be resolved soon
I would suggest opening a TAC SR so that the bug can be attached to the SR and it gains more visibility.
Manish
Please rate all helpful posts and mark as Answered if appropriate
