10-11-2019 04:39 PM
I am using Jabber Version 12.7.0 (288631) on Mac Book pro and after Mac OS upgrade to Catalina ( 10.15 ) the option attach ( send file) doesn't work anymore.
Has someone the same problem ? Or if I need to change some configuration on the Mac ?
11-06-2019 02:05 AM
I am running Jabber 12.6.0 (281201) and even after upgrading to MacOS Catalina the file attach functionality works fine.
11-06-2019 02:14 AM
Probably in your case Jabber does not have access to various folders and hence is not able to attach files from them
