Jabber Click to dial popup
anthony.lotito1
I am looking for a way to disable the "Use Cisco Jabber to Call?" popup when users click on a number they want to dial.
I have created a UC Service and applied that to my Service Profile using The Common and Desktop drop downs under Jabber Client Configuration (Jabber-config.xml) Profile with no change in the popup behavior.
When I pull up the Cisco Jabber Diagnostics (Ctrl+Shift+D) and I look at the Jabber configuration file, all I see is "falsefalse"
EnableTelProtocolPopupWindow / CiscoTelProtocolPermissionEnabled
Applies to Cisco Jabber for Windows.
Specifies whether the dialog box is enabled or disabled, which provides information for users to confirm if they want to make a call using Cisco Jabber, after they click ciscotel:uri enabled number.
  • true (default)—Dialog box is enabled, and users are asked to confirm that they want to place the call.
  • false—Dialog box is disabled, and the call is made without requesting confirmation first. This may cause accidental or unwanted calls.
Example: <CiscoTelProtocolPermissionEnabled>false</CiscoTelProtocolPermissionEnabled>
ClickToCallProtocolPermissionEnabled
Specifies if the dialog box is enabled or disabled, which provides information for users to confirm if they want to call using Cisco Jabber, after they click clicktocall: uri link.
  • true(default)—Dialog box is enabled, and users are asked to confirm if they want to use Cisco Jabber to call.
Example: <ClickToCallProtocolPermissionEnabled>false</ClickToCallProtocolPermissionEnabled>
I used this Doc to review and make my selections:  Parameters Reference Guide for Cisco Jabber 14.0
Is there any way to disable this "Use Cisco Jabber to Call?" popup?
UCM Version: 12.5.1.14900-63
Jabber Version:14.0.4.56553 Build 306553
Jonathan Schulenberg
What is the protocol handler of the link you are clicking on? I do not believe these flags control the generic tel: handler, only ciscotel: and clicktocall:.
Does the app behave as expected if you create a link using one of those two handlers? If not, did you refresh the config client-side (under the Help/About menu IIRC)? The client only grabs a config update periodically.
I had the url set to tel:
Once I updated to clicktocall: or ciscotel: it works as it should
Thanks for the nudge in the proper direction.
