Jabber for Samsung Galaxy S3
cgmiller913
I have a brand new Samsung Galaxy S3 running ICS. I have Anyconnect running just fine, I tried installing Jabber Client, and I keep getting the following error message:
Please check your Internet Calling Setting and try again. If the problem persists, contact your system administrator.
For device ID, I am using BOTXXXX naming convention and for server I am putting the IP address of the Publisher, but tried DNS name as well, but that did not work either.
I am running CUCM 8.5.1.12900-7 and I just installed the cmterm-android_8.6.2v17b.cop.sgn on my publisher and subscriber nodes and rebooted all.
I basically followed this document to the T:
http://www.cisco.com/en/US/products/sw/voicesw/ps556/products_configuration_example09186a0080bb5104.shtml
Any help would be appreciated. Thanks!
Chris
28 Replies 28
Phillip,
My apollogies. I thought the doc was read-only
I could have updated it.
Thanks!
Adam
Phillip,
Any idea when the S3 from Sprint will be supportted for Jabber Android?
I'm not aware of any established timeline.  If you find an update from Sprint that lets it work please make a note of it in the documented I linked above.
Is this a Sprint issue or a Cisco issue?
Hi Phillip,
Does Cisco or anyone has explanation why some Android phones with certain Android OS/Baseband versions are experiencing this issue " Please check your Internet Calling Setting and try again...." ?
Tiberie
gregory wenzel
I have the same issue with my sprint S3 i see its not supported yet.
johnkenn
I upgraded to:
Android 4.0.4,
Baseband Version: I9300XXLH1
Build Number: IMM76D.I9300XXBLG8
and this seems to work (previously I had the same error, I believe it's an ICS issue that's fixed with this newer update)
John
Which carrier?
I am able to connect to my CUCM 8.6.2aSU1 using the Jabber Client Version 9.0.2.2122. I am also able to make outgoing calls. HOWEVER, I cannot receive incoming calls, no idea why, the phone does not ring, and when calling Voicemail I could not press 1 4 or 7 as the PIN. I am wondering what is wrong. Using S3 International with LH1 Baseband. Anyone experience similar issues?
AdamSchrack
Good morning all,
Recieved an update from Verizon last night, and I am able to get  the device registered with CUCM. Haven't done much testing yet, but Visual Voicemail is a no-go so far.
Samsung Glalxy S3 -
Model Number
SCH-I535
Android Version
4.0.4
Baseband Version
I535VRLG7
Kernal Version
3.0.8-993945-user
se.infra@SEP-90 # 1
SMP PREEMPT Fri Aug 3 00:53:23 KST
2012
Build Number
IMM76D.I535VRALG7
Hardware Version
I535.10
Cisco Jabber -
Version 9.0.1.2042
CUCM -
8.5.1.11900-21
Adam
Confirmed the above. After the Verizon update Jabber is working. I'm able to place and receive calls. Working great so far, hope Cisco implements Jabber chat soon as well in this client.
Chris
Only two issues thus far:
1) Visual Voicemail configuration causes the Jabber Client to crash. The only way to rectify has been to uninstall the client, then reinstall leaving the Visual Voicemail configuration un-configured.
2) There is no option to take the call via bluetooth headset once the call is active. You can initiate and recieve a call from the Bluetooth headset, but once you've connected without the headset you are stuck with speaker, or "handset".
Otherwise - all is well... short of the lacking IM/Chat, Presence, and Video capabilities of coarse .
Adam
rew
Level 4
Level 4
Is there a configuration guide for setting up Jabber For Android on Cisco?  I have downloaded the application from App Fridge.  I need to get the configuration information.
Someone has configured Samsung Galxy S Duos. Below are details.
Model
Galaxy S Duos
GT-S7562L
Android Version
4.0.4
Baseband
S7562LVJLK1
Kernel Version
3.0.8-1162058
Tks.
