Jabber Guest Sample code for iOS - ERRORS
rmoreton1
Community Member
I am trying to develop a Jabber Guest app for a customer. I downloaded the sample xcode projects and attempted to run ABC Bank, to see how a it one would work. The build failed and I received the error: " No architectures to compile for (ONLY_ACTIVE_ARCH=YES, active arch=x86_64, VALID_ARCHS=i386). " Any help is appreciated.
I've attached a screenshot of the error message
Aditi Seth
From the screenshot it looks like you are using a simulator to run the sample apps. For the sample apps to work you have to build using a device. Running on a simulator is not supported.
It's on our roadmap to add support to build via simulator.
Aditi Seth
