10-01-2012 02:38 AM - edited 03-17-2019 02:39 PM
Hi All,
Recently we have received a license file from cisco as one of our customer has requested the Jabber for thier working enviorment.They will use jabber for thier windows based desktop clients, for android phone, iPhones, iPad and Blackberry.
Customer has CUP 8.0 with CUCM 8.0 enviorment with no active directory.
cisco has sent the below license files.
Product Description Entitlement Qty
CUP-86-K9-SW-PAK CUP 8.6 SW Kit & PAK 1
JABBER-IM-RTU Jabber for Everyone Right to Use 1
it contains the 1200 user licenses.
i have searched alot but fail to find any document from cisco which describes that where do i put this license either on CUP or CUCM.
pls help me to understand that:
where should i add the license file ?
is there any configuration required on CUP ?
is there any configuration required on CUCM ?
how do i configure it on blackberry ?
if there any Video link is availble which describes these steps or any document then pls share.
your reponse will be highly appriciated.
10-01-2012 05:10 AM
CUCM
Yes
Yes
You only enable the user for CUPS/CUPC on CUCM once you've done all the basic config for CUCM user/device/line
Cisco Jabber for Windows 9.0.x Administration Guide
http://www.cisco.com/en/US/partner/docs/voice_ip_comm/jabber/Windows/9_0_1/b_jabber_win_icg.html
ALL the jabber guides are available on CCO, just search "Jabber for
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
10-11-2012 11:57 PM
what about below license file ?
10-12-2012 12:15 AM
i did not found any PAK key in the document where it shows this:
