Jabber iPhone and Android Display Name issue
CUCM and IMP Version 10.5.1
Jabber Client version  : 10.6
Display Name when I logged into  the Client appear as userid@localdomain instead of Fist Name_Last Name like the windows client ;I already read threads on this on the forum suggesting changing the display name mapping in the jabber-config.xml file' I already did that with no changes at all, how do I fix this issue?.
Jaime Valencia
Your directory integration is not working, have you properly configured your BDI integration in jabber-config.xml???
java
if this helps, please rate
I can search the Directory for usersbu t it is only the display name that have an issue,is there is any document out there that contain the detailed procedure  on how to configure the jabber-config.xml file  for iPhone and  Android?
thanks,
The jabber deployment and installation guide contains all the settings you can have in the jabber-config.xml, along with the explanation of what each one does. There is no longer a guide per platform, they have all been integrated into a single doc.
java
I will Double check this again and I will update this case once it is solved.
