Meeting Place 8.0.1.2 and ccm 8.6.2 compatibility confirmation
spvaidya
We wish to upgrade our CCM from version 8.0.1 to 8.6.2 which is integrated with meeting place version 8.0.1.2. We have searched for the compatibility on cisco.com and found following two references. We also checked with PDI and they have recommended to use ccm 8.5 or upgrade meeting place to 8.5.
Does anyone have meetingplace 8.0.1.2 and cucm 8.6.2 integrated ?
Note - We have meeting place for audio conference meetings only at the moment. Due to other application requirement we have to upgrade to cucm to 8.6.x.
URL 1 <<----- This states that,
For audio-only installations, you may connect Cisco Unified MeetingPlace to Cisco Unified Communications Manager Release 6.0(3) or later release: this is for Meeting Place 8.0
http://docwiki.cisco.com/wiki/Cisco_Unified_MeetingPlace_Release_8.0_--_System_Requirements_for_Cisco_Unified_MeetingPlace_Release_8.0#Cisco_Unified_Communications_Manager
URL 2 <<----- This states that,
Component name
Component Version
6.1(2) - 8.0
Release Date
Nov. 12, 2007 - Mar. 26, 2010
http://docwiki.cisco.com/wiki/Cisco_Unified_MeetingPlace_Release_8.0_--_Compatibility_Matrix_for_Cisco_Unified_MeetingPlace_Release_8.0
Also, in the compatibility tool , It states that
http://tools.cisco.com/ITDIT/vtgsca/VTGServlet
Goto release -->>8.6->Conferencing ->Cisco Unified MeetingPlace
8.6.(1) compatible version is - Initial  8.5(1).
Shashank
anchoudh
Level 9
Level 9
Hi Shashank,
The fact that CUCM 8.6.2 is not specified in the MP8.0 documentation means that MP8.0 hasn’t been officially tested with that version of CUCM, and hence cannot be stated it is officially supported. Since MP8.0 is end of sale, there won’t be any additional testing of this product, and hence CUCM 8.6.x won’t be added to the documentation at any time.
It may work but it is not officially supported by the BU.
Anand
Please rate helpful posts !!
Dear Anand,
Thanks for your reply. I got your message, But I wanted to check with other folks who has this scenario and their experience/observation.
Hi Shashank,
Please avoid deploying a setup which is not supported  according to documents. It might run for several years without any issue  or it might not run even for a single day. If it is not tested it is  not supported.
Consider a scenario when this deployment works fine for couple of  months into production and then you face some issue. TAC & BU will  not be able to help you.
Atul
