MFT via Expressway MRA and federated contacts
thorstenn
Level 4
Level 4
Hi, anyone know the necessary steps to enable MFT via Expressway MRA ?
Internal its configured and working. What steps needs to be done for external Managed File Transfer to federated contacts?
Thx in advance
Jaime Valencia
AFAIK MFT is not supported over XMPP or SIP federation, only om-prem or via intercluster peer.
java
if this helps, please rate
Ok. So from expressway release notes its written that MFT is supported. But thats only for two participants which are connected through MRA from the sam company, correct?
Are there any plans for supporting file send, screen capture,.... in future releases for MRA federated contacts?
Yes, that would be two (or more) of your IM&P users over MRA, not with a federated contact.
Roadmap questions cannot be addressed at CSC as that's NDA material, if you're a partner, you would need to ask in the partner communities, or reach out to your SE for that kind of information.
java
I have same issue MRA Deployment in which external jabber client cant share file to others .
error:File upload failed.
But Internal Jabber client is able to share file and external client can successfully download that file.
Is this a Firewall related issue.
CUPS-10.5.2
