MP Web 8.5.5.2 : SQL Exception when attending webmeeting
iantra123
Level 3
Level 3
Does anyone already experienced SQL Exception withe MeetingPlace Web Server?
The Meeting Can be created, but when I want to connect on the webmeeting, I see this error on the popup.
The error below is on the event viewer of the webserver.
Does anyone know the reason? How to resolve it?
Antra
Arun Kumar
Hi Antra,
Is this a new install of above version or migration from previous (what version?) ?
Was it working before?
Any recent changes? which resulted in this issue.
Once have above info will be able to provide more insight into this.
Arun
Hello Arun,
It's a new and upgraded install 8.5.5.
I've installed from 8.5.2 and upgraded it to 8.5.5.
What I've done to have this issue :
. I've created a meeting (schedule or immediate meeting), from the web-interface.
. Then I click in the button connect.
. A popup appear, and it shows the SQL Exception Error.
Antra
Request you to kindy raise a TAC case so will be easy to fix this issue.
Arun
