I will suggest to take pcap on client jabber pc and diagnostics logs on both expresswayc/E and pcap on internal endpoint as well and see on which point it is getting dropped?
Most of the time it is firewall but you can only see through pcaps.
Please rate if it is helpful...
Please rate if it is helpful and mark as accepted solution if applicable....
