Not registering over WIfi
pcromwell
Level 3
Level 3
We have cucm 11.X and Jabber Iphone clients on 11.X If registering for the first time on the system, they fail. If we turn Wifi off on the Iphone, we can register via 3/4G via the MRA on VCS-Expressway without any issues.the issue seems to be with just the Iphones as we can do the same process with the Android and it connects no problem. Also Jabber for windows works fine. has anyoone had the same issue?
Jaime Valencia
What troubleshooting have you done??
Have you looked at a PRT to see the connection attempt and try to get an idea of what is failing?
java
if this helps, please rate
I have looked at the PRT and it states a TFTP error when looking for the users xml config file
but I have run packet traces on cucm and looked at tftp logs and I see them xfer. We have checked all along the network route and it is the same route as the other devices
OK, so you see request to find the user, you get the associated devices and then you try to download the device.cnf.xml file, you should see a 200 OK if it's found and a request number, then the data that was received.
This is from a J4W PRT as I don't have one right now for iOS
2016-07-04 11:18:18,324 INFO [0x00002324] [ls\src\http\BasicHttpClientImpl.cpp(399)] [csf.httpclient] [csf::http::executeImpl] - *-----* HTTP response code 200 for request #1374 to https://CUCM11PUB:6972/CSFBHINDS.cnf.xml
2016-07-04 11:18:18,326 INFO [0x00002324] [ls\src\http\BasicHttpClientImpl.cpp(431)] [csf.httpclient] [csf::http::executeImpl] - HTTP response code 200 for request #1374
2016-07-04 11:18:18,326 DEBUG [0x00002324] [ls\src\http\BasicHttpClientImpl.cpp(446)] [csf.httpclient] [csf::http::executeImpl] - For request #1374 the total size of the data received is: 11339, the size of the response body is: 11339
So, you're seeing the transfer from the TFTP server being sent to the device, but the device doesn't show it actually received any data?
java
So on the CUCM TFTP Log I ge tthe following which looks good and it sends the 200 ok.
however I don't see the 200 ok at the Iphone end on a Friewall capture.
00441105.000 |07:18:51.077 |AppInfo  |   TID[e48f9b70] HTTPEngine::getRequest(), [0xa90bb58~496~127.0.0.1~47222] INFO:: File Requested TCTJohndoe.cnf.xml
00441106.000 |07:18:51.077 |AppInfo  |<--TID[e48f9b70] HTTPEngine::getRequest(), [0xa90bb58~496~127.0.0.1~47222]
00441107.000 |07:18:51.077 |AppInfo  |-->CReqContext::tftp[0xa90bb58~496~127.0.0.1~47222]
00441108.000 |07:18:51.077 |AppInfo  |CReqContext::CheckAndSetIsStatic(tctJohndoe.cnf.xml) is (Not a Static) File
00441109.000 |07:18:51.077 |AppInfo  |CReqContext::isCTLCAPFRequest[TCTJohndoe.cnf.xml] Not a CTLCAPF File
00441110.000 |07:18:51.077 |AppInfo  |CReqContext::isRinglistRequest[TCTJohndoe.cnf.xml] Not a Ringlist File request
00441111.000 |07:18:51.077 |AppInfo  |CReqContext::FindAndServe SignFileFlag[0]
00441112.000 |07:18:51.077 |AppInfo  |CCtftpChangeNotifyServer::HasWaitingEvent(), Empty List or pkid
00441113.000 |07:18:51.077 |AppInfo  |CReqContext::FindAndServe(1)[0xa90bb58~496~127.0.0.1~47222],[(TCTJohndoe.cnf.xml),(12142),(0xe869b428)] found in config cache
00441114.000 |07:18:51.077 |AppInfo  |-->CReqContext::serve[0xa90bb58~496~127.0.0.1~47222]
00441115.000 |07:18:51.077 |AppInfo  |-->CReqContext::isECDSAEncryptedConfigFile[TCTJohndoe.cnf.xml]
00441116.000 |07:18:51.077 |AppInfo  |<--CReqContext::isECDSAEncryptedConfigFile[TCTJohndoe.cnf.xml]
00441117.000 |07:18:51.077 |AppInfo  |-->CSendBuffer::Init[0xa90bb58~496~127.0.0.1~47222]
00441118.000 |07:18:51.077 |AppInfo  |<--CSendBuffer::Init[0xa90bb58~496~127.0.0.1~47222]
00441119.000 |07:18:51.077 |AppInfo  |-->HTTPEngine::sendResponse[0xa90bb58~496~127.0.0.1~47222]
00441120.000 |07:18:51.077 |AppInfo  |   HTTPEngine::sendResponse[0xa90bb58~496~127.0.0.1~47222] FileName[TCTJohndoe.cnf.xml], Version[HTTP/1.1], Size[12142]
00441121.000 |07:18:51.077 |AppInfo  |   HTTPEngine::sendResponse[0xa90bb58~496~127.0.0.1~47222] INFO:: [86][HTTP/1.1 200 OK
