Problem_Jabber_IPhone(IOS)
Kvant
Jabber runs "Push Notifications Settings" on the Android platform, but the iPhone does not work on the Apple (iOS) platform
In all versions of ios.
Jabber version 14.0.3.306210
what could be the reason?
Jaime Valencia
Someone recently posted about a certificate change that affected APNS, take a look at that thread, it was quite recent.
java
if this helps, please rate
b.winter
Hi Kvant,
as Jaime mentioned, there has already been a post with probably the same issue:
https://community.cisco.com/t5/unified-communications/apns-for-jabber-stopped-working-overnight/m-p/4494177#M168957
Please check, if maybe you hit the same issue.
Mahmoud Belhaj
hello
check your certificate, device start within TCTxx and setting in JABBER
