have reg here to find some solutions for my problem with Cisco jabber.Will be VERY happy if you can help me. There is problem with Cisco jabber ,I am from IT solution center and many users have problem with :
Skype search not working.
Skype meeting for outlook .
Online status not available in Outlook.
Some users had problem with Log in to Cisco jabber
After research from internet I have found solution - The problem was solved via regedit - HKEY-Current user - Software - IM Providers ( and here in DefaultMApp need to make sure Lync is set default, or type it if not) After that need to restart outlook. This Solution solved all the problem, but after restarting (PC/Laptop )problems occurs again , because DefaultMApp sets Cisco jabber as default again . if you know the solution or someone who would know it , can you pls let me know asap. best regards Dias K
