Problem with jabber 9.2 and Office 2010 and IE 8
Does someone know if jabber for windows 9.2 can make a click to call with Internet Explorer.
It's ok with outlook 2010 and word but NOK with excel.
Thanks for your answer.
Best regards.
skomazec
Hi Valery,
This feature in Outlook is called Click to X.
Click to Call currently doesn't existes with Jabber and it is targeted for Jabber 9.6 release.
Srdjan
Hi Srdjan,
Thanks for your answer, but the last release of jabber is 9.2.Do you know when the release 9.6 will be propose for download on cisco.com ?
Valery.
If the url is prefixed with tel: then you can click to call in all the office apps as far as I'm aware. I could be wrong though. Fairly sure I've tested it in excel
