Room Kit Pro built-in microphone
yun zhang
Hi Guys Is there a Room kit pro with a built-in microphone . The farthest speaker is about 4 meters from the VC . Does built-in microphone support for Sound pickup for 4 meters?
zy
Vaijanath Sonvane
Cisco WebEx Room Kit Pro does not have built-in microphones. It is recommended to use Cisco Table - or Ceiling microphones.
Only following Root Kit endpoints has built-in microphones:
1. Cisco WebEx Room Kit
2. Cisco WebEx Room Kit Plus ( Note: For Room Kit Plus, the integrated microphones are for speaker tracking only)
You can refer to Best Practices Guide for Video-Enabled Rooms for microphone distance:
https://projectworkplace.cisco.com/assets/pdf/best-practice.pdf
Please rate helpful posts and if applicable mark "Accept as a Solution".
Thanks, Vaijanath S.
