Spark and Webproxy with HTTPS inspection
Hi all.
We have a Webproxy that does HTTPS inspection, this means that all web-traffic goes through and by the time it returns to my computer the certificates is re-issued by our proxy.
This is causing SSL negotiation to fail for Spark.
Here is from the log:
2016-01-06 10:51:02,087 ERROR [28] Certificate.CertificateValidator - SSL cert chain for original host locus-a.wbx2.com eventual host locus-a.wbx2.com does not match pinned cert
2016-01-06 10:51:02,088 ERROR [28] Api.WdmClient - error from host locus-a.wbx2.com, message The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel.
2016-01-06 10:51:02,088 ERROR [28] Api.ApiWrapper - CheckIfOnline failed, trying again in 60000ms.
System.Net.WebException: The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel. ---> System.Security.Authentication.AuthenticationException: The remote certificate is invalid according to the validation procedure.
The way I see it I have 2 options:
1. have our proxy by-pass all connections to ciscospark.com
     This could work but I am afraid that it would only work for Spark in browser, this is because in the log file for the client I see that it is a different address than ciscospark.com.
2. Spark must ignore the certificate issues.
Am I correct?
Any advice would be much appreciated.
-alex
davebro2
Community Member
Hi Alex,
Your assessment is correct.  To be clear, what's going on is that the non-browser Spark clients have implemented certificate pinning  as a security measure to prevent a man-in-the-middle attack .
Because disabling pinning would leave us vulnerable security-wise, the recommended configuration of a proxy is not to modify HTTPS traffic to the following domains:
*.wbx2.com
identity.webex.com
idbroker.webex.com
If there is a need to inspect content, Spark is developing a governance and compliance tool that allows an enterprise customer to inspect data for policy compliance of their org.
Dave
davebro2
Community Member
Hi Alex,
*.wbx2.com
identity.webex.com
idbroker.webex.com
Dave
Hey.
Getting those domains bypassed in our proxy did the trick!
