Spark call connector downloading infinite
ruben.rojas
Que tal team de communities, a alguien le ha tocado este problema con spark, tenemos un cliente y estamos en plena instalación de Spark en conjunto de CUCM como servicios de hybrid,
La situación está de la siguiente manera:
1-. La parte de los certificados ya se realizó.
2-. La conexión de Expressway Hybrid al Cloud Collaboration Management es donde se están presentando los problemas
·         Managment Connector : se conecta pero nos presenta un error
·         Call Service se queda descargando y no avanza
Acciones realizadas:
·         Se a realizo rollback de version del Managment Connector.
·         Se dio reset y reboot al expressway hybrid.
·         Se desactivaron los servicios de call service y se volvieron a levantar.
·         Se volvió a cargar el certificado de Cisco.
Por otra parte, las personas encargadas de los DNS externos, no pueden levantar el TXT Record.
Adjunto pantallas
Bienvenidos sean sus comentarios...
gracias
Ruben Guardado
keglass
Level 7
Level 7
Translation of post:
As a team of communities, someone has touched this problem with spark, we have a customer and we are in full Spark installation in CUCM set as hybrid services,
The situation is as follows:
1-. The part of the certificates has already been made.
2-. The Expressway Hybrid connection to Cloud Collaboration Management is where problems are occurring.
· Managment Connector: connects but gives us an error
· Call Service remains downloading and does not progress
Actions done:
· I made a rollback version of the Managment Connector.
· Reset and reboot the expressway hybrid.
· Call service services were deactivated and raised again.
· The Cisco certificate was reloaded.
On the other hand, the people in charge of the external DNS, can not raise the TXT Record.
Attached screens
Welcome to your comments ...
Thank you
keglass
Level 7
Level 7
Ruben,
Since you are a Cisco Partner, I recommend you post this to the Spark space in the Cisco Partner Community for more appropriate feedback and information.
Spark
I hope this helps.
Kelli Glass
Moderator for Cisco Customer Communities
