Spark Room Shortcut
johcastr
In the Spark application is there a way to create/copy a shortcut or link for a specific Spark room?
6 Replies 6
George Thomas
Level 10
Level 10
If its a space with more than one participant, if you click on the "Waffle" icon on top right, select "Meetings", it should give you the link to join a specific space. I am not sure if this is what you are after or looking for shortcuts within the Spark application.
Please rate useful posts.
johcastr
Thank you George for your reply. Your advice is helpful but not exactly what I need.
What I need is a link for a space that I can send via chat or email that will direct them to the team space.
If you want a way for people to join a space, take a look at the "Eurl" bot. (eurl@sparkbot.io).
Can't find this on the spark depot. Can you advise how this works pls?
You invite the bot to the space just like you would with any other bot/person.
Once you invite the Eurl bot to your space, how does one determine the url for that specific space so that the link can be copied and shared?
