02-08-2018 08:47 AM - edited 03-17-2019 07:20 PM
Hi. I have the following question over cms conference, if is possible have annotation tools such as pencil or pointer in cms. How could it be implemented?
Solved! Go to Solution.
02-08-2018 09:46 AM
02-08-2018 09:46 AM
05-06-2018 08:46 PM
Hi Patrick,
do you have some example for 3rd party software ? like annotation in webex
05-07-2018 12:15 PM
The whiteboard feature in Webex Teams (aka Spark) is only supported within the cloud at the moment, on-premise endpoint aren't able to receive the whiteboard as presentation content. A workaround is you could open a whiteboard and present your computer screen showing the Webex Teams application.
A quick Google search came up with the following software applications, I'm sure there are others.
