Unity Connection Data Export - how does it work?
gfolens
Level 7
Level 7
On the CCO downloads for Unity Connection v14 I found: ciscocm.cuc_DataExport_v1.1.zip.
There is also a Readme document but still after reading this it is not clear what this utility is doing and how it works.
Where can I find more information about this tool?
I also see no support for any Cobra's tool on CUC v14.
I'm looking for a way to migrate from v11.5 to a new VM running v14 without the need to upgrade v11.5 first.
2 Accepted Solutions
Ratheesh Kumar
Hi there
ciscocm.DataExport_v1.0.cop  - This cop will install the CLI which would allow user to export the data. It copies the respective CLI xml file and the script files to run the dataexport.
I can see the Cobras is supported with CUC 14.
http://www.ciscounitytools.com/Applications/General/COBRAS/COBRAS.html
Compatibility   -
Connection 7.x, 8.x, 9.x, 10.x, 11.x, 12.x, 14
Hope this Helps
Cheers
Rath!
***Please rate helpful posts and if applicable mark "Accept as a Solution"***
Fresh install with data export is a new feature introduced with latest versions of UC applications.
Fresh Install with Data Import: Cisco Unity Connection 14SU1 and later releases, supports installation of Unity Connection along with the data import from the previous releases. It involves migration of data by exporting source release data to SFTP server, and installing a new machine with import of that data. Examples of data that you can export and import are component specific configurations files, voicemails, DB related files, platform provision data and platform files like certificates
https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/connection/14/install_upgrade/guide/b_14cuciumg/b_14cuciumg_chapter_00.html
Response Signature
Ratheesh Kumar
Hi there
Compatibility   -
Hope this Helps
Cheers
Rath!
Response Signature
