Webex Connect integration with UC5x0
bjames
Level 5
Level 5
Hi just wondering if this integration is possible now with 8.6 of the UC5x0 code, if so can someone point me to me to the docs.
In the Connect cloud administration page it says the UC integration is only available for version 6.x and lower?? We are running 7.2
Thanks in advance,
Bob James
mvild
That message applies to "Click to Call".  Look below you will see the other "integration" options.  Click to call was something that the older client version is compatible with only.
Also, use the Connect Admin guide.. all the documentation is there.  You can easily do a search to find what you are looking for...
http://www.webex.com/webexconnect/orgadmin/help/index.htm?toc.htm?18648.htm
Your OrgAdmin must be provisioned to support Unified Communications. If not, just have your Cisco account person send open a Remedy ticket to have this done.
This is what I see when I click to add a new cluster and then choose Enable Cisco UC Manager Express integration with Cisco WebEx Connect:
5 Replies 5
mvild
That first tab was set with the initial UC integration and that specific tap "General" will only apply for customers who deply the older version of Connect (6.x) for various reasons.
Use the Clusters tab to configure your CUCM servers, which does support CUCM 8.6.
Sorry for the confusion.
bjames
Level 5
Level 5
Yes I understand it's the client, we are running 7.2.1 Build 16886 of the client. When I open the client it says "Service not available, please contact your system administrator (me) under the Unified Communications settings hence me going to the admin portal and seeing that message.
Does something on the backend (Cisco) have to be enabled for this?
Bob James
Same message under clusters.
Just to be clear this is a UC5x0 system which is basically CME
mvild
"Your OrgAdmin must be provisioned to support Unified Communications. If not, just have your Cisco account person send open a Remedy ticket to have this done." - Bingo
I opened a ticket on this because all my settings were greyed out.
Still waiting for it to be done....
Bob James
