Webex conversion to flv producing different audio and video lengths
daryl.lannert
I am trying to convert two webex files to flv.  When I do that it ends up producing audio files that are the correct length and video files that are shorter than the actual program.
keglass
Level 7
Level 7
Daryl,
If you are still have difficulty with converting your files to flv, then I recommend you contact WebEx support directly for help with troubleshooting.
Support Tools and Resources | WebEx
Kelli Glass
Moderator for Cisco Customer Communities
