04-18-2017 03:58 AM - edited 03-17-2019 06:48 PM
I have a customer subscribed to Cisco Cloud Webex Meeting Center and they are looking to integrate with their existing CUCM to make audio calls and video with internal extensions.
Is this scenario is doable? what are the required license to achieve this?
04-18-2017 04:36 AM
You have two options, depending from the size of your customer.
For large customers, ask for Cloud Connected Audio, which is a direct SIP peering over a dedicated L2 connection.
The alternative is to enable Collaboration Meeting Room (Cloud) on the site. This enables max 25 attendees call in from video endpoints. CUCM registered endpoints are OK. This solution needs an Expressway pair for correct firewall traversal.
04-18-2017 04:58 AM
Thanks Idemeter for your comment, the number of Webex users are 20 users which i believe should go with second option, the second option will give only video calls and what about Audio calls for non video phones ?
04-18-2017 05:49 AM
Take a look at this thread I believe you are asking for the same here. There is a roadmap but since this post in a public area it would have to be moved to partner side
04-18-2017 08:06 AM
Audio-only SIP phones can also join CMR-C enabled meetings just like PSTN phones. And SIP callback is also possible.
04-18-2017 08:20 AM
Yes but you then pay for an audio plan with WebEx or the CCA Provider. If you wanted to avoid that, then that's why I recommended moving to partner community
