Webex Mobile wi-fi to LTE handoff
aalejo
Level 5
Level 5
Dear Community:
On CUCM 14  a feature called "Wi-fi to LTE call handoff"  was added (together with a supported expressway version) to webex app (mobile + windows) . There are a few limitations (like recording)  but nothing mentioned about network conditions required or how this feature really works of if it can be disabled (for compliance purposes for example)
A few questions pop up:
- Why LTE is needed?
- Can it be disabled?
- The only requirement is that device be able to login from wi-fi and from WAN?
- Can be use across multiples expressway clusters?
- What was added to version 14 to support this feature?
- How feature really works? (this will respond all the rest :))
Thank you!
Alex
0 Replies 0
