WebEx not working on Chrome 64bit?
Saqib Ali
14 Replies 14
lucarastello
None yet, other than reverting back to Chrome 32bit.
Well, I did uninstall all the Cisco WebEx related programs from "Control Panel"->"Programs and Features", re-installed them, and it still wouldn't work (i.e. I couldn't join meetings). I reverted to Chrome 32bit, and it started working again (i.e. I could join meetings). Re-installed Chrome 64bit, got prompted to add the Cisco WebEx extension, and it worked fine again.
Hope this helps.
Luca,
Is that the Webex Chrome Extension or the Webex Addon (Cisco_WebEx_Add-On.exe)?
I uninstalled the Webex  Addon, uninstalled Chrome and installed Chrome 64. Still getting the same old Add On  (Cisco_WebEx_Add-On.exe) from Cisco, which doesn't work with Chrome 64.
Saqib
No,
it was a Chrome extension. Should be available free from the Chrome Extension store.
Luca
lucarastello,
I am not seeing it in the Chrome Web Store. Can you please me the direct link to the WebEx Chrome Extension?
Thanks!
Saqib
Hi, the link is here: Cisco WebEx Extension - Chrome Web Store
Hope that helps.
Luca
Hello Luca,
Thanks for the link to the Chrome Extension. I installed it. But I am still unable to join a WebEx. I even uninstalled the old WebEx Add On from the Windows Add / Remote Programs.
Any suggestions?
Saqib
Boaz Aviani
Cisco folks,
I'm surprised that there is no solution seen to run Webex using Chrome 64 bit
WHAT'S GOING ON WITH YOU !!!!
It causing a lot of problem on each Webex call.  Many users can't join the calls and it delays the sessions !!!
I believe that this issue shall be treated top urgently but it seems to me that it doesn't bother anyone.
leonardocasale
I'm in the same boat.  As others have states before, Cisco_WebEx_Add-On.exe does not install.  Trying to install the add-on does nothing (no screen, no windows process, nothing).  The WebEx extension doesn't work either.  The only thing that works for Chrome 64 is downloading the "Temporary application" each time I go to join a meeting.
Would love a response from Cisco on the matter...
abradish
Hi Everyone,
There is a lot going on here and I apologize for the confusion.  Let me explain what is going on and what can be done.
Background
Great news, Chrome 64-bit support is here or coming soon! On Chrome, WebEx is in the middle of a transition from using Plugins to join a meeting to using a Chrome Extension.  Adding to the confusion, Chrome just released a new 64-bit version of their browser.  As this is being posted, our code to allow you to join via Extension is rolling out so you should be able to join using Chrome 64-bit already or soon depending on your site.  It takes few weeks to update all sites so please give your site until September 17th*.
Answer
To answer your question, can I join a meeting on Chrome 64-bit? Yes, you need to meet the requirements below:
Requirements to join on Chrome 64-bit (Chrome Extension)
  1. Chrome 38+**
  2. One of these versions of WebEx (http://kb.webex.com/WBX84336)***
Chrome 38 is currently the beta version and can be downloaded here.  It will be going to the Stable channel in about a month (release dates are subject to change per Google)
Workaround (if needed)
If your site has not upgraded yet or you cannot use Chrome 38+ then please use one of the following workarounds until your site meets the requirements:
  1. Use Chrome 32-bit
  2. Use Firefox, Internet Explorer, or Safari (Mac only)
* Some companies have chosen not to update their site and will not get the Extension update.  Without the update, WebEx cannot support Chrome 64-bit.  Rollout dates are subject to change.
** To check your Chrome version
  1. Open Chrome
  2. Type the following into your address bar and press enter: chrome://chrome/
*** To check your WebEx site version
  1. Navigate to your site
  2. Click "Support" in the left NAV
  3. Click "User Guides" in left NAV
  4. Look for the "Application version" on the right side
abradish, thanks for official response
Will this Chrome Extension also work on ChromeOS / Chromebook?
@Saqib Ali - The Chrome Extension will not work on ChromeOS / Chromebook.
@Srinivasan Kilambi - Please clear your cache and try the KB link again
If I click on the WebEx KB link I got this
We're very sorry. There was a problem and we weren't able to process your request. Please try again!
Thank you Andrew, that's exactly what I was looking for.
