Webex Teams application login problem
selina1
Frequent Visitor
Frequent Visitor
 i can't connect to my webex teams account using the application on my windows PC (my device has the necessary requirements for the applicaton)
The health checker points Upgrade, Notifications, Admin, Authentication as impacted Services.  Any solution ideas?
Jaime Valencia
Might want to use the Webex support
https://www.webex.com/support/
java
if this helps, please rate
PJMack
Level 11
Level 11
Did you click on the test link? What were the results? Or you can go to mediatest.ciscospark.com and do a test from there.
In all liklihood you have ports blocked that are required.
