Meddane
Create two SIP Trunk Security Profiles to listen on different SIP port for Call Recording 5070 and Auto Attendant 5062.
Create two SIP Profiles.
Create two SIP Trunk.
The first SIP Trunk will be used for Call Recording, use 5070 as the destination port. Assign the previous SIP Trunk Security Profile and SIP Profile.
The second SIP Trunk is for routing calls to Auto Attendant, use 5062 as the destination port. Assign the previous SIP Trunk Security Profile and SIP Profile.
Create a Route Pattern 19XX to route calls to Imagicle Auto Attendant Service and assign the SIP Trunk.
Create a Route Pattern 8282 to route the recorded calls to Imagicle Call Recording and assign the SIP Trunk.
Create a Recording Profile with a pattern 8282 and assign it to a Phone at the line level.
Enable the Built-in-Bridge at the Phone level.
Imagicale Auto Attendant Configuration
Create an Auto Attendant with a telephone number 1982.
Edit the Auto Attendant and define three behaviours for example and sets the action Transfer to with the Queue number that should processes the call in the Call Queuing. Define the Caller input digit for Menu navigation.
Create four queues with the same number defined in the Behaviours. In the Call distribution of each Queue define the agents or users that should take the call.
5 Comments
Blue_Bird
Thanks for sharing..!! @Meddane
Martin L
Indeed, interesting usage of "old" soccer player
thanks dear @Meddane
"imagicle" solution is awesome & very stable .. you can complete rely on it even in large scale projects..
last year, i deploy it for one large customer with more that 5000 calls per day
and so far, it is working very good & nice..
i recommend this "imagicle" solution as a Gold Service for Cisco UC environment ^-^
Meddane
@Mohammadreza Hadi  Thanks for your feedback and additional informations.
ibrahim Adhami
For Imagicle recording part, just add the configuration under line page config to assign the recording profile and enable the automatic recording
