Ayodeji Okanlawon
Often times this is one of the most misunderstood aspect of a CUBE configuration. This stems from our knowledge of how bind commands work with h323 gateway. Typically when deploying h323 gateway with CUCM we need to configured h323 bind commands on the interface that we will use for h323 traffic.
Once this is defined, this interface IP address is seen on CUCM for the gateway. Hence all h225 signaling and h245 media negotiations will be directed towards this interface.This is good for H323 and doesn't create any issues for us. However this doesn't work the same way on a SIP to SIP CUBE solution. Question is why?
On a traditional H323 to TDM PSTN connection, we only have one leg of VoIP traffic, so all h323 signaling is directed towards that leg. The other leg is a TDM either digital PRI, or Analogue FXO ports. In this setup where we apply signaling and media traffic doesn't need much consideration as it can only be done on one leg of the call.
On a H323 to SIP connection, even though we have two VoIP legs, the leg that usually connects to the PSTN is the SIP leg. In this case we usually apply sip signalling and media to the outside leg that connects to the ITSP..This works okay too without any issues….
However since most people are migrating to a full homogenous SIP solution this becomes very important to know where to apply your sip bind commands. This is because in most deployment, customers typically have two different interfaces. One interface connects to the LAN, and the other Interface connects to the ITSP. In this scenario applying the bind command wrongly on a SIP to-SIP CUBE, has the potential to remove the listener from the external interface and in some cases create a one way audio problems
Lets look at an example to understand this last point
Here is the scenario:
CUCM-----SIP---CUBE---SIP---ITSP
NB: CUCM IP is 192.168.12.190, ITSP 10.205.20.50
CUBE Interface config
interface GigabitEthernet0/0
Decription LAN interface
ip address 192.168.10.5 255.255.255.0
interface GigabitEthernet0/2
Decription Connection to ITSP
ip address 172.29.25.246 255.255.255.252
duplex auto
speed auto
voice service voip
sip
bind all source-interface gig0/0
In this example, all sip signaling and media traffic will be sent to gig0/0, the LAN interface on the CUBE. What is wrong with that you may ask…Well a lot!
Let’s look at a sample trace for an outbound call originating from CUCM towards the CUBE..
Received:
INVITE sip:0447014824@192.168.10.5:5060 SIP/2.0
Via: SIP/2.0/TCP 192.168.12.190:5060;branch=z9hG4bK78adb3ecc5092
From: "5399" <sip:5399@192.168.12.190>;tag=1729466~70e9433b-1d79-44ae-9a16-09a52be377c5-30642592
To: <sip:0447014824@192.168.10.5>
Sent:
INVITE sip:0447014824@10.205.20.50:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.10.5:5060;branch=z9hG4bK2C9207D
Remote-Party-ID: "5399" <sip:8065399@192.168.10.5>;party=calling;screen=yes;privacy=off
From: "5399" <sip:8065399@192.168.10.5>;tag=242A3EF4-1315
In this scenario what we see is this…All sip traffic originates and terminates on the LAN interface. Hence when CUBE sends an INVITE to the ITSP it uses the Local LAN interface also. This presents a problem because the ITSP cant talk to CUBE on the Local LAN Interface. In one case I looked at the INVITE didn't even make it to the ITSP because we never got any response from them. This is most likely because the LOCAL interface doesn't have any route to the ITSP network.
Some folks rather than binding on the local interface will bind on the interface facing the ITSP.
The major problem with this is:
CUCM will not accept any sip traffic coming from an IP address that is not configured on its sip trunk.
Lets look at a sample trace..CUCM SIP trunk configured with ip address 192.168.10.5
Received:
INVITE sip:0344556677@172.25.29.246:5060 SIP/2.0
Via: SIP/2.0/TCP 10.10:5060;branch=z9hG4bK78adb3ecc5092
From: <sip: 0447014824@10.205.20.50:5060>;tag=1729466~70e9433b-1d79-44ae-9a16-09a52be377c5-30642592
To: <sip: 0344556677@172.25.29.246>
Sent:
INVITE sip:5399@192.168.12.190:5060 SIP/2.0
Via: SIP/2.0/UDP 172.25.29.246:5060;branch=z9hG4bK2C9207D
From: <sip: : 0447014824@172.25.29.246>;tag=242A3EF4-1315
In this case, we can see that CUBE has sent out on INVITE to Cisco call Manager using the external interface.
The result of this is call failure. This is because CUCM is going to reject the call with “501 service unavailable” due to the fact that the IP address from which sip traffic originates and to which CUBE has indicated it want to receive a response back (through the via header) is not the ip configured on the SIP trunk on CUCM.
How do we then address SIP binds on deployments like this:
There are two ways to address this. The first is
  • No SIP BIND COMMANDS AT ALL
Don't use sip binds command at all. Yes you heard me, this is because you shouldn't need a SIP bind on SIP to SIP because the IOS on CUBE will source from the interfaces closest to the destination of the SIP packet.
In this scenario without a sip bind, CUBE will receive traffic on the Local interface and will send out INVITE to the ITSP on the ITSP interface and all will be well.
However there are scenarios where this won’t work either.I recently had one of those scenarios.
CUBE was selecting the MPLS interface on the router as the destination closest to CUCM, but because this interface was not the one configured on the sip trunk, CUCM rejected the call.
We then decided to configure this interface on the sip trunk..Everything worked except there was no audio. It turned out that this subnet was not reachable from the IP Phones Subnet. So question is what do we do..If we configure bind on one interface we had issues. When we didn’t, CUBE selected the wrong interface to originate and terminate sip traffic..This brings us to our second method
  • USE BIND COMMANDS on DIAL-PEER
Example..........
dial-peer voice 15 voip
description outbound dial-peer to CUCM
voice-class sip bind control source-interface GigabitEthernet0/0
voice-class sip bind media source-interface GigabitEthernet0/0
dial-peer voice 1 voip
description inbound from CUCM
dial-peer voice 2 voip
description inbound from ITSP
voice-class sip bind control source-interface GigabitEthernet0/2
voice-class sip bind media source-interface GigabitEthernet0/2
dial-peer voice 20 voip
description ***outbound dialpeer to ITSP***
In the config above, when traffic originates or terminate from or to CUCM-CUBE, the local interface will be used for both SIP signalling and Media traffic. When calls originate or terminate from ITSP to CUBE the external interface to ITSP will be used.
Sample trace
Received:
Sent:
Remote-Party-ID: "5399" <sip:8065399@172.25.29.246>;party=calling;screen=yes;privacy=off
From: "5399" <sip:8065399@172.25.29.246>;tag=242A3EF4-1315
What we see here is how things should be..
CUCM sends invite to CUBE on its local interface and CUBE sends INVITE to ITSP on the external interface.
74 Comments
You have no idea how much this helped me. Very good article i has trouble with inbound and outbound calls to/from SIP trunk. The binding on the dial-peers helped me completly.
Thank you so much,Biljana.
Ron-Schutte_2
Hi all,
i am in the same situation. and figured out that we also needed to bind it per dial-peer.
only problem we have is how and where is determent where the response to OOD (options ping) is sourced.
we are using cube in HA setup whit a external VIP and a internal VIP.
the ITSP is using OOD to check if the trunk is up, from the inside we do the same. from cucm we check if the trunk is up.
The problem is that the response to OOD is sourced from either the outside VIP or inside VIP. debinding on the bind configuration.
anybody got a clue if it's possible to configure how the cube response to OOD messages ?
regards Ron
johnsgeorge
Nice post!
From the post - This is because in most deployment, customers typically have two different interfaces. One interface connects to the LAN, and the other Interface connects to the ITSP.
What if there is only one interface both for the LAN and the ITSP sides? i.e if the ITSP can reach the LAN interface (eg. if the ITSP provides the MPLS circuit as well or similar scenario)
Is it mandatory to have 2 separate interfaces? From the security perspective, however if the nearest interfaces are selected by the sip traffic, the internal interface is not visible to the ITSP/outside. Even if it is visible, how can someone reach the internal interface, as it might not be reachable from the outside interface mostly.
Johns
Ayodeji Okanlawon
Hi John,
In a scenario where you have only one interface, you most times don't need to apply any bind command. However if you want to then you should apply the bind command to the single interface under the sip-ua config level.
No it is not mandatory. We only have one interface in my deployment.  With two interfaces, your bind statements needs to be applied at dial-peer level as explained in the blog
johnsgeorge
Cisco doc says about 2 separate interface, mainly for security purpose. In the case of only one interface what do we lack?
Ayodeji Okanlawon
Two separate interfaces is better, from a security point of view. If you have a private mpls cloud to the itsp, then you can use a single interface. If you don't have a private cloud then ensure you use two separate interfaces.
johnsgeorge
But even in the case of a public network to ITSP, if there is no route between the internal interface and the public one, how can anyone reach the internal interface? What is the security threat?
Ayodeji Okanlawon
In most cases your provide will deploy an edge router that will route between your internal network and their network. One way or another you have to ensure that there is IP routing between the two network. Security wise I am not an expert, but you will have to ensure that your internal network is secured
johnsgeorge
ok..Thank you so much. :-)
Nice read btw..
GASHAW TURA
I have similar project where I have to replace the existing ISDN/PRI PBX with Digium switchvox SIP PBX. The Scenario will be  SIP PBX --------- Cisco IOS Gateway ----------MPLS -------VZB SBC.
**Existing working Scenario is PRI PBX --------Cisco IOS Gateway -------MPLS-----VZB SBC.
The existing configuration has the bind statement on "voice service VoIP" configuration to bind the outbound interface on the MPLS side where SIP calls coming. The dial-peer was also configured for VoIP and pots to accept SIP calls from VZB MPLS network.
The question i have here is, what changes I need to include in the Cisco IOS gateway to establish a new sip trunk with Digium Switchvox and make SIP to SIP calls while keeping the same configuration on the VZB SBC side? The above article seem providing me a guidance that I can retest tonight by changing the sip bind configuration at the dial-peer level but I am not sure the Digium SIP PBX will bring up the sip trunk if configured with the internal Cisco IOS gateway private IP (Gi0/2).
Any help on similar project will help me move forward in solving this puzzle and I will appreciate any idea on this.
Planned changes on Dialer-peer configuration to swap the existing POTs dial-peer with SIP PBX-
"dial-peer voice 20  voip
 description OUTBOUND Voice SIP
 translation-profile outgoing DIGITSTRIP-9
 destination-pattern 9T
 rtp payload-type nte 98
 session protocol sipv2
 session target sip-server
 voice-class codec 1
 voice-class sip early-offer forced
voice-class sip bind control source-interface GigabitEthernet0/1
voice-class sip bind media source-interface GigabitEthernet0/1
 dtmf-relay rtp-nte
 no vad
dial-peer voice 501 voip
description switchvox
preference 1
destination-pattern 703456….
voice-class codec 1
session target ipv4:10.1.X.X
session transport tcp
incoming called-number 703456….
forward-digits 4
dtmf-relay rtp-nte
dial-peer voice 500 pots
 preference 2
 progress_ind alert strip 8
 direct-inward-dial
 port 0/0/0:23
 forward-digits 4
dial-peer voice 200 voip
 description voip dial peer - from proxy
 incoming called-number .T
 voice-class codec 1
 dtmf-relay rtp-nte
 ip qos dscp cs5 media
 ip qos dscp cs3 signaling
 no vad
Preference 1
destination-pattern 526788….
voice-class codec 1
forward-digits 4
dtmf-relay rtp-nte
dial-peer voice 502 pots
 preference 2
 direct-inward-dial
 port 0/0/0:23
 forward-digits 4
dial-peer voice 551 voip
preference 1
voice-class codec 1
dtmf-relay rtp-nte
no vad
dial-peer voice 550 pots
 preference 2
 direct-inward-dial
 port 0/0/0:23
***Any idea, if i need any configuration to reflect the new SIP PBX under sip-ua configuration other than the above dial-peer change, which is already configured with sip-server of the provider proxy.
Ayodeji Okanlawon
You should apply the bind statement to the interface that connects to the SIP PBX. If that's gig0/2, then that should be fine. The same applies to the VZB SBC. If the interface is 0/1, then apply the bind statement there too..
I can see that you have changed the payload number for nte to 98. Is this what the SIP PBX is using for nte?
This dial-peer (551) is going to create issues for you. This is because all your inbound sip calls including calls from the SBC will match this dial-peer due to the incoming called number .
I am sure you don't want that. You need inbound calls from each call leg to have their signalling matching the correct interface. hence you will need to define specific dial-peers for inbound calls from both pbx and sbc..
preference 1
GASHAW TURA
Ayodeji, Thank you for your quick look on the planned configuration change. The rtp payload type nte 98 is towards the providers SBC and I am keeping the existing configuration. I will remove this if it is going to affect the interoperability with the SIP PBX. I will be creating more specific dial-peer for incoming called-number to avoid confusion.
tfertodd18
I am trying to find out the relevance of the SIP bind commands when implemented on inbound dial-peers.  I totally get the SIP bind commands relating to outbound dial peers.  I don't understand the point of binding interfaces for SIP on inbound dial peers.  In the network set up above it is the originator of the call (i.e. the sender of the initial INVITE) that chooses the destination IP address on the CUBE for the INVITE packet.  Then surely the CUBE must respond to the INVITE request using that same IP address as the source  of the reply messages (i.e. for the 100 Trying, 180, 200 OK replies).  So why must one configure a bind command on inbound dial peers?
Todd
PS.  Although I have much SIP experience from a SP (soft switch) side of things, I am a bit new to the way Cisco implement SIP so please excuse me if this is a silly question.
GASHAW TURA
I have tested the configuration- I have successfully established outbound calls but inbound calls are failing due to a 407 challenge from the peering SIP Digium Switchvox PBX.
The failure looks on the Digium PBX side due to calls from unknown source.
Let me know, if you have encounter similar interoperability issues.
Ayodeji Okanlawon
Gashaw,
Please open a separate thread on the IP telephony forum and you will have enough hands to help on this.
