Sometimes when you install Cisco Unity Connection. You get an error caused by hardware check. To successfully install Cisco Unity Connection, you need to bypass the hardware check.
![Meddane_0-1667857951534.png Meddane_0-1667857951534.png](https://community.cisco.com/t5/image/serverpage/image-id/167303iDD6C16BA662099D4/image-size/large?v=v2&px=999)
Open your ISO image using the UltraISO tool. Navigate to the folder Cisco > install > conf.
Locate the callmanager_product.conf file.
![Meddane_1-1667857951560.png Meddane_1-1667857951560.png](https://community.cisco.com/t5/image/serverpage/image-id/167304i50E8D4E843B2A572/image-size/large?v=v2&px=999)
Right-click on the file and click Extract To. Choose a location on your PC.
![Meddane_2-1667857951580.png Meddane_2-1667857951580.png](https://community.cisco.com/t5/image/serverpage/image-id/167305iFAF71FE086843BE7/image-size/large?v=v2&px=999)
![Meddane_3-1667857951598.png Meddane_3-1667857951598.png](https://community.cisco.com/t5/image/serverpage/image-id/167308iA3EC4A7EABA6065D/image-size/large?v=v2&px=999)
On your PC, open the callmanager_product.conf file. Seach keyword id="connection". Change the Value in the last line from NOT, to VAL.
Before:
![Meddane_4-1667857951601.png Meddane_4-1667857951601.png](https://community.cisco.com/t5/image/serverpage/image-id/167306i18EB640594D51C1D/image-size/large?v=v2&px=999)
After:
![Meddane_5-1667857951604.png Meddane_5-1667857951604.png](https://community.cisco.com/t5/image/serverpage/image-id/167307iD4C2CC8D8CE857A2/image-size/large?v=v2&px=999)
Replace the callmanager_product.conf file as shown below.
![Meddane_6-1667857951626.png Meddane_6-1667857951626.png](https://community.cisco.com/t5/image/serverpage/image-id/167310i574E28627EEB46AF/image-size/large?v=v2&px=999)
Save the ISO image as shown below.
![Meddane_7-1667857951647.png Meddane_7-1667857951647.png](https://community.cisco.com/t5/image/serverpage/image-id/167311i657AA43B5E0788FF/image-size/large?v=v2&px=999)
Now the hardware check is bypassed for your Cisco Unity Connection installation.
![Meddane_8-1667857951648.png Meddane_8-1667857951648.png](https://community.cisco.com/t5/image/serverpage/image-id/167309iA699A8FC169C86F6/image-size/large?v=v2&px=999)
