abbasali5
I need to get 100 VCS-C traversal and 200 VCS-E traversal calls VM servers running 12.5.
I am also trying to convert my old VCS licenses fromVCSC/E.
Can't find any reliable guide on CCO about licenses, and conversion of old licenses.
Can someone shed a light? Please
2 Comments
Ayodeji Okanlawon
This thread should be posted in the collaboration question forum not as a blog...use the ask question button to ask for help..
You can use your smart license portal to generate licenses for your expway solution.
Expwe:
TOP SKU: LIC-EXP-E-PAK
SKU: LIC-EXP-GW        Expressway GW Feature Set
              LIC-EXP-SERIES   Expressway Series Feature Set
              LIC-EXP-E             Expressway-E Feature Set 1.0
              LIC-EXP-TURN     TURN Relay
             LIC-EXP-AN          Expressway Advanced Networking
These licenses should be registered to the SN of your expwe
Expwc
TOP SKU: LIC-SW-EXP-K9    SW VERSION UPGRADE
These license should be registered to your expwc
To migrate licenses send an email to license@cisco.com
Also if you don't have access to your smart license portal then send. License request to licensing too to request your expressway licenses.
Does that server is in contract if yes please go to https://slexui.cloudapps.cisco.com/SWIFT/LicensingUI/Quickstart# click on All license , click on get the license, select telepresence release key or license & put the SN to get the license.
- Rishabh
Please remember to rate responses and to mark your question as answered if appropriate.
