The following document will help you connect your Web Browser to an existing Video or Audio System. This demo describes the steps needed to connect a WebRTC capable Web Browser, (Google Chrome, Google Chrome Canary, FireFox, FireFox Nightly) to an existing Audio and Video system (Cisco TelePresence Server, McuWeb, Cisco Codian MCU.)
The components used in this demo are:
Components | Version |
Google Chrome Canary | 33 canary |
Mobicents | mss-2.0.0.FINAL-jboss-as-7.1.2.Final |
Opencall sip servlet B2BUA | opencall-1.1.0-BELADOR |
WebSockets sip servlet | websockets-sip-servlet-2.1.0-20121108.113957-1 |
Doubango webrtc2sip | webrtc2sip 2.6.0 |
Doubango sipML5 | sipML5 Doubango version 203 |
Architecture
By using Doubango SipML5 we utilize HTML5 SIP client entirely written in JavaScript. The client is used to connect to any SIP or IMS network from WebRTC-capable browser to make and receive audio/video calls. This SIP client registers to Telestax WebSockets Sip Servlet via WebSockets protocol that runs on top of Mobicents Server. For more information please review TeleStax:
https://code.google.com/p/sipservlets/wiki/HTML5WebRTCVideoApplication
Usage
In order to dial from your web browser you have two options:
Utilize pre-defined parameters (Demo system)
No need to deploy any component, you will be using pre-deployed systems in Amazon AWS.
1) Access:
http://webrtc.ramennetworks.com/
2) Configure parameters
Parameter | Description | Recommended value |
Display Name: | Caller Name | Chrome |
Private Identity*: | Calling number | +14082221000 |
Public Identity*: | From URI | |
| Enable Interop | Enable H.264 support | Enable |
This modified HTML page is already configured to use Amazon AWS servers. You can enable Developer mode JavaScript console view in Web Browser to see values.
sipRegister() (index):353
s_websocket_server_url=ws://webrtc2sip.ramennetworks.com:5062 tsk_utils.js?svn=20:116
s_sip_outboundproxy_url=tcp://172.31.46.56:5060 tsk_utils.js?svn=20:116
b_rtcweb_breaker_enabled=yes
3) Login
4) Dial number
You can use any valid SIP URI. Example: 22223333@videolab.att.com,testcall@video.att.com
Configure your own parameters and servers and dial to any public or local SIP URI
Access via HTTP the following page:
From there click on Enjoy our live demo.
Public Identity*: | From URI | sip:+14082221000@opencall.org |
Password: | Password | 14082221000 |
Realm*: | Domain | 172.31.46.56 |
If you want to enable H.264 codec you need to go to expert mode and enter the following:
Enable RTCWeb Breaker | Enables webrtc2sip utilization | Enabled |
WebSocket Server URL | webrtc2sip server | ws://webrtc2sip.ramennetworks.com:5062 |
SIP outbound Proxy URL | mobicents websockets sip servlet | tcp://172.31.46.56:5060 |
Deploying
The following table describes the steps necessary steps to deploy this system:
| Components | Deployments steps |
| Google Chrome Canary | Install |
| Mobicents | Download, Install, Configure |
| Opencall | Download, Configure, Deploy |
| WebSockets Sip Servlet | Download, Deploy |
| Doubango webrtc2sip | Download, Install, Configure |
| Doubango sipML5 | Configure |
Google Chrome installation
https://www.google.com/intl/en/chrome/browser/
Mobicents installation
http://sourceforge.net/projects/mobicents/files/Mobicents%20Sip%20Servlets/
mss-2.0.0.FINAL-jboss-as-7.1.2.Final-1349104459.zip
http://github.com/spicyramen/opencall/blob/Development/config/standalone-sip.xml
Move standalone-sip.xml file to this director:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/bin and
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration
Obtain local IP address information and define which NIC system will be using ifconfig
Example:
ifconfig
lo0: flags=8049<UP,LOOPBACK,RUNNING,MULTICAST> mtu 16384 options=3<RXCSUM,TXCSUM> inet6 fe80::1%lo0 prefixlen 64 scopeid 0x1 inet 127.0.0.1 netmask 0xff000000 inet6 ::1 prefixlen 128gif0: flags=8010<POINTOPOINT,MULTICAST> mtu 1280stf0: flags=0<> mtu 1280en0: flags=8863<UP,BROADCAST,SMART,RUNNING,SIMPLEX,MULTICAST> mtu 1500 ether 20:c9:d0:42:af:7d inet6 fe80::22c9:d0ff:fe42:af7d%en0 prefixlen 64 scopeid 0x4
inet 192.168.1.69
netmask 0xffffff00 broadcast 192.168.1.255 media: autoselect status: activep2p0: flags=8843<UP,BROADCAST,RUNNING,SIMPLEX,MULTICAST> mtu 2304 ether 02:c9:d0:42:af:7d media: autoselect status: inactive
Go to the following folder in order to start Mobicents server:
./standalone.sh -b 192.168.1.69 -c standalone-sip.xml &
Opencall Installation
https://github.com/spicyramen/opencall/blob/Development/target/opencall-1.1.0-BELADOR.war
Create opencall folder in mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration
Example:
mkdir mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall
https://github.com/spicyramen/opencall/blob/Development/config/opencall.ini
Configure proper file location inside Opencall.ini define path for Opencall server routing rules.
MODE=1
RULE_LIMIT=100
FILELOCATION=/Users/gogasca/Documents/OpenSource/Development/Java/Mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/Opencall/Opencallrules.cfg
https://github.com/spicyramen/opencall/blob/Development/config/opencallrules.cfg
Move Opencall war file to the Mobicents deployment folder:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
Verify Opencall war is deployed successfully, verify Opencall log and server log file in log folder: the Opencall log file is named: Opencall-engine.log, server log is server.log
Example:
21:55:33,724 INFO [org.jboss.as.server] (ServerService Thread Pool -- 29) JBAS018559: Deployed "
opencall-1.1.0-BELADOR.war.deployed"
16:10:32.095 INFO [Opencall] [Thread-160] | Opencall engine has started succesfully.
WebSockets Installation
*File may be already included in Mobicents zip file, so this instruction may not be required.
Verify Websockets war is deployed successfully, verify server log file in log folder: the server log file is named: server.log
21:55:33,723 INFO [org.jboss.as.server] (ServerService Thread Pool -- 29) JBAS018559: Deployed "websockets-sip-servlet-2.1.0-20121108.113957-1.war"
websockets-sip-servlet-2.1.0-20121108.113957-1.war.deployed
Webrtc2sip Installation
Follow the instructions described here, if you want to enable media conversion:
You have the option to install from source or install the packages:
http://autostatic.com/installing-webrtc2sip-on-ubuntu-1204#building_from_source
Mobicents configuration
For Mobicents please make sure you configure configuration file properly.
Configure your Default Application Router Configuration and define the proper Application Name.
INVITE: Opencall
REGISTER: WebSockets
Opencall configuration
Configure opencall.ini and define the initial system configuration settings
Configure opencall.ini and define the System Routing rules in order to connect Mobicents to your external system.
Opencall System Configuration
Opencall server will look for opencall.ini located:
mss-2.0.0.FINAL-jboss-as-7.1.2.Final/bin and mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall in order to start succesfully
opencall.ini
MODE
1 - LOCAL FILE
2 - DB (MYSQL DB)
3 - LOCAL RULES (BUILT-IN) (Not implemented)
DB TYPE
DB TYPE
1 - MYSQL TODO
2 - MONGO DB TODO
3 - MICROSOFT SQL SERVER TODO
MODE 1 must have FILEROUTINGRULES
MODE 2 must have DBTYPE,DBHOSTNAME,DBPORT,DBNAME,DBUSERNAME and DBPASSWORD
MODE 3 does not need any parameters (Not implemented)
Example:
MODE=1
RULE_LIMIT=100
CALLTRANSFORMS=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencalltransforms.cfg
CALLRULES=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencallrules.cfg
CALLROUTELIST=/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/configuration/opencall/opencallroutelists.cfg
DBTYPE=1
DBHOSTNAME=localhost
DBPORT=3306
DBNAME=opencall
DBUSERNAME=root
DBPASSWORD=
Opencall Route Configuration
Opencall have the option to read call routing rules from a configuration file or from a MySQL DB.
This document describes how to configure opencallrules.cfg to provide call routing rules in order to connect to your system.
Mandatory parameters:
RULE = NUMERIC
PRIORITY = NUMERIC
TYPE = REGEX, WILDCARD, NUMERIC
STRING = VALUE
TARGET = IP ADDRESS, HOSTNAME, _DNS_, ROUTELIST
Optional
PORT and TRANSPORT is not configurable when using _DNS_ lookup
PORT and TRANSPORT is not configurable when using RouteList, you can define parameters there.
Rule Entries Order
RULE NUMBER,RULE PRIORITY, RULE TYPE, MATCH STRING,TARGET, PORT TARGET, TRANSPORT
Example:
ROUTE=("1","10","NUMERIC","14082186000","110.10.0.210","5060","UDP")
ROUTE=("2","5","REGEX","(.*)@videolab.att.com","_DNS_")
ROUTE=("3","10","NUMERIC","201","172.31.43.74","5060","TCP")
ROUTE=("4","10","WILDCARD","20X","172.31.43.74","TCP")
ROUTE=("5","10","WILDCARD","10X","110.10.0.200")
ROUTE=("6","10","WILDCARD","XXXXXXXX","videoalpha.att.com")
ROUTE=("7","10","WILDCARD","XXXXXXXX","videolab.att.com","WSS")
ROUTE=("8","100","WILDCARD","20X","110.10.0.210","5060")
ROUTE=("9","50","WILDCARD","0115255!","110.10.0.200","5060")
ROUTE=("10","50","WILDCARD","0115233!","110.10.0.200","5060")
ROUTE=("11","1","NUMERIC","+525553259000","110.10.0.200","5060")
ROUTE=("12","1","WILDCARD","4XX","110.10.0.220","5060")
ROUTE=("13","100","REGEX","(.*)@.*","_DNS_")
ROUTE=("14","5","REGEX","(.*)@videolab.att.com","_DNS_","5061")
ROUTE=("15","5","REGEX","(.*)@videolab.att.com","_DNS_","TCP")
ROUTE=("16","100","REGEX","(.*)@videolab.att.com","12.5.4.3","TCP")
$ pwd
/Users/gogasca/Documents/OpenSource/Development/Java/Mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
$ ls -al
-rw-r--r-- 1 root root 11 Feb 28 2013 jolokia.war.deployed
-rw-r--r-- 1 root root 1169838 Nov 6 07:58 opencall-1.1.0-BELADOR.war
-rw-r--r-- 1 root root 26 Nov 6 07:58 opencall-1.1.0-BELADOR.war.deployed
-rw-r--r-- 1 root root 8870 Jul 16 22:33 README.txt
-rw-rw-r-- 1 root root 408732 Nov 6 00:37 sip-servlets-management.war
-rw-r--r-- 1 root root 27 Nov 6 00:37 sip-servlets-management.war.deployed
-rw-rw-r-- 1 root root 649785 Nov 6 00:35 websockets-sip-servlet.war
-rw-r--r-- 1 root root 26 Nov 6 00:35 websockets-sip-servlet.war.deployed
WebSockets configuration
$ pwd
/usr/local/src/mobicents/mss-2.0.0.FINAL-jboss-as-7.1.2.Final/standalone/deployments
$ ls -al
Chrome configuration
SipML5 configuration
The live demo doesn't require any installation and can be used to connect to any SIP server using UDP, TCP or TLS transports. Open the following URL and start provisioning information. Open the following URL:
You must be a registered user to add a comment. If you've already registered, sign in. Otherwise, register and sign in.
