Quigath
Symptoms
 I wanted to test the custom logging functionality.
Diagnosis
 There's an easy Library to use.
Solution
 I made a sample class that matches the Activity Log for Element entry events.
package logging;
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileWriter;
import java.io.IOException;
import java.nio.file.Path;
import java.nio.file.Paths;
import java.text.SimpleDateFormat;
import java.util.Calendar;
import com.audium.server.global.LoggerApplicationAPI;
import com.audium.server.logger.ApplicationLoggerBase;
import com.audium.server.logger.LoggerPlugin;
import com.audium.server.logger.events.ApplicationEvent;
import com.audium.server.logger.events.ElementEnterEvent;
import com.audium.server.logger.events.EventException;
import com.audium.server.logger.events.IEventIDs;
 * Programming guide:
 * https://www.cisco.com/c/en/us/td/docs/voice_ip_comm/cust_contact/contact_center/customer_voice_portal/cvp11_6/programming/guide/ccvp_b_programming-guide-for-cisco-unified-11-6/ccvp_b_programming-guide-for-cisco-unified_chapter_01100.html#CCVP_TP_A55E3990_00
public class CustomAppLogger1 extends ApplicationLoggerBase implements LoggerPlugin {
  private static final String DELIMITER = ",";
  private BufferedWriter writer = null;
   * Called on app start.
  @Override
  public void initialize(File configFile, LoggerApplicationAPI globalAndApplicationData) throws EventException {
    eventsToListenFor.add(ELEMENT_ENTER_EVENT_ID);
    eventsToListenFor.add(ELEMENT_DEFAULT_INTERACTION_EVENT_ID);
    Path logFilePath = Paths.get(getLogFileDirectory(), "customLogFile.log");
    try {
      writer = new BufferedWriter(new FileWriter(logFilePath.toString()));
    } catch (IOException e) {
      e.printStackTrace();
   * Called on app end, restart, redeploy
  @Override
  public void destroy(LoggerApplicationAPI globalAndApplicationData) {
    if (writer != null)
      try {
        writer.close();
  @Override
  public void log(ApplicationEvent eventAndEnvironmentInformation) throws EventException {
    String eventID = eventAndEnvironmentInformation.getID();
    if (eventID.equals(IEventIDs.ELEMENT_ENTER_EVENT_ID)) {
      logElementEnterEvent(eventAndEnvironmentInformation);
  private void logElementEnterEvent(ApplicationEvent event) {
    ElementEnterEvent enterEvent = (ElementEnterEvent) event;
    SimpleDateFormat sdf = new SimpleDateFormat("MM/dd/yyyy kk:mm:ss.SSS");
    try {
      writer.append(enterEvent.getLoggerAPI().getSessionId()).append(DELIMITER);
      Calendar cal = enterEvent.getTimestamp();
      sdf.setTimeZone(cal.getTimeZone());
      writer.append(sdf.format(cal.getTime())).append(DELIMITER);
      writer.append(enterEvent.getElementName()).append(DELIMITER);
      writer.append("enter").append(DELIMITER);
      writer.append(""); // description of what happened, no delimiter after last item
      writer.append("\n");
    } catch (Exception e) {
      try {
        writer.append("\nexception=" + e.toString());
      } catch (IOException ioe) {
        ioe.printStackTrace();
    } finally {
      if (writer != null) {
        try {
          writer.flush();
