This document was generated from CDN thread
Created by: Mert Guray on 10-06-2011 08:18:37 AM
The log files collected under "Cisco\CVP\VXMLServer\CommonLogs" are rotating with 1000 files each having 10MBytes. Which adds up to 10 GBytes of space. I want to decrease this. But couldn't find the conf. file for it. Do you know where to change the settings.
Thanks.
Subject: RE: CommonLogs rotation
Replied by: Tieying Xuan on 12-06-2011 11:26:37 PM
Open the application in Call Studio, open the project properties window. The log settings can be opened in follow path, "Call Studio -> General Settings -> Logger (Select Activity log) -> Click "Edit" button on the right side of the log list -> on the popup, click "Edit" button on the right of "Include configuration file" check box".
I think you need <purge> tag in the configuration file.
Replied by: Mert Guray on 22-06-2011 02:23:54 AM
I think you are talking about the activity logs of an application. This one is more general, and it is under VXMLServer\CommonLogs.
Replied by: Stacy Johnson on 23-06-2011 01:59:48 PM
I am not aware of any VXML Server folder by the name VXMLServer\CommonLogs. These logs might be the result of some customer jars.
