Created by: Chuck Brier on 11-11-2009 05:28:13 PM I¿m in the process of writing some extraction java classes to export phones in a CCM V4.2(3) Sr4b with the goal of adding these phones to a UCM V7.1.3. I downloaded the axltoolskit from the UCM V7 servers and built the java classes using AXIS 1.4. I built sepraate libraries for Callmanager V4 and V7. I cleared the errors in all the classes per the axl programming guide. I am able to get a list of phones by executing the ListPhoneByDescription method to get a list of device names. I then try to execute a getPhone method passing a string representing a device name to the V4.2(3) Call Manager. I receive java exception stating ¿Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone ¿ commonProfileName¿.
I run this same code against a UCM 7 server using the classes generated by 7.1 schemas and the code works. I try this same code built off the 7.1 schema to the 4.2(3). I get the same exception ¿Invalid element in com.cisco.www.AXL.API._7_1.XIPPhone - commonProfileName. ¿ gust a diffrent scheme reference. I searched the AXLAPI.wsdl and axl.xsd files(schemas 1 & 7) for a reference to commonProfileName and find no references in the schemas. I took a look at the wsdl and xsd files on call manager 4.2(3) in c:\ciscowebs\api\axl\v1. I search the axl.xsd and do find a reference to commonProfileName. I tried to build a new classes based off these files; however, the wsdl and xsd files are not valid. I took files off other call manager 4.2(3) servers with the same results.
How do I resolve this issue with 4.2(3)?
Code:
import java.net.MalformedURLException; import java.rmi.RemoteException; import java.security.Security; import javax.xml.rpc.Call; import javax.xml.rpc.ServiceException; import org.apache.axis.client.Stub; importorg.apache.axis.types.UnsignedLong; import com.cisco.www.AXL.API._7_1.*; import com.cisco.www.AXLAPIService.AXLAPIService; import com.cisco.www.AXLAPIService.AXLAPIServiceLocator; import com.cisco.www.AXLAPIService.AXLPort; publicclass GetPhoneAttributesV4 { publicstaticvoid main (String Args[]){ String cluster = "CM"; String axlURL = "https://CM-A/CCMApi/axl/v1/SOAPISAPI.dll"; String axlUserName = "username"; String axlPassword = "password"; String deviceName = "SEP001795B134BA"; //Cm2 GetPhoneAttributesV4 getPhone = new GetPhoneAttributesV4(); try{ // Install the all-trusting trust manager Security.addProvider( new NilProvider() ); Security.setProperty( "ssl.TrustManagerFactory.algorithm", "TrustAllCertificates"); System.out.println("Trying AXL Request"); AXLAPIService service = new AXLAPIServiceLocator(); System.out.println("Trying AXL Port - get bindng to url"); //Get the binding for RisPort AXLPort axlport = service.getAXLPort(new java.net.URL(axlURL)); System.out.println("Trying Setting Username & Passowrd"); ((Stub)axlport)._setProperty(Call.USERNAME_PROPERTY,axlUserName); ((Stub)axlport)._setProperty(Call.PASSWORD_PROPERTY, axlPassword); getPhone.getSinglePhone(deviceName,axlport); } catch (ServiceException e) { System.err.println("Error connection to host: "+ e.getMessage()); return; } catch (MalformedURLException e) { // TODO Auto-generated catch block System.err.println("Error URL is Bad:"+ e.getMessage()); e.printStackTrace(); } } publicvoid getSinglePhone(String name,AXLPort axlport){ try{ GetPhoneReq getPhoneReq = new GetPhoneReq(); getPhoneReq.setPhoneName(name); System.out.println("getphone via axl port"); GetPhoneResReturn value = axlport.getPhone(getPhoneReq).get_return(); System.out.println("Move to local variable for XIPPhone"); XIPPhone phone = value.getDevice(); System.out.println("Moveed.. to local variable for XIPPhone"); System.out.println(phone.toString()+ "\n Model: "+phone.getModel()+ "\n CSS: "+phone.getCallingSearchSpace()+ "\n CSS Name: "+phone.getCallingSearchSpaceName()+ "\n DEVICE POOL: "+phone.getDevicePoolName()); } catch (RemoteException e) { // TODO Auto-generated catch block e.printStackTrace(); } } }
Exception
Trying AXL Request Trying AXL Port - get bindng to url Trying Setting Username & Passowrd - Exception: org.xml.sax.SAXException: Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone - commonProfileName at org.apache.axis.encoding.ser.BeanDeserializer.onStartChild(BeanDeserializer.java:258) at org.apache.axis.encoding.DeserializationContext.startElement(DeserializationContext.java:1035) at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:165) at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141) at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:236) at org.apache.axis.message.RPCElement.getParams(RPCElement.java:384) at org.apache.axis.client.Call.invoke(Call.java:2467) at org.apache.axis.client.Call.invoke(Call.java:2366) at org.apache.axis.client.Call.invoke(Call.java:1812) at com.cisco.www.AXLAPIService.AXLAPIBindingStub.getPhone(AXLAPIBindingStub.java:11441) at com.britek.ucm.realtime.GetPhoneAttributesV4.getSinglePhone(GetPhoneAttributesV4.java:65) at com.britek.ucm.realtime.GetPhoneAttributesV4.main(GetPhoneAttributesV4.java:41) AxisFault faultCode: {http://schemas.xmlsoap.org/soap/envelope/}Server.userException faultSubcode: faultString: org.xml.sax.SAXException: Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone - commonProfileName faultActor: faultNode: faultDetail: {http://xml.apache.org/axis/}stackTrace:org.xml.sax.SAXException: Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone - commonProfileName at org.apache.axis.encoding.ser.BeanDeserializer.onStartChild(BeanDeserializer.java:258) at org.apache.axis.encoding.DeserializationContext.startElement(DeserializationContext.java:1035) at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:165) at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141) at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:236) at org.apache.axis.message.RPCElement.getParams(RPCElement.java:384) at org.apache.axis.client.Call.invoke(Call.java:2467) at org.apache.axis.client.Call.invoke(Call.java:2366) at org.apache.axis.client.Call.invoke(Call.java:1812) at com.cisco.www.AXLAPIService.AXLAPIBindingStub.getPhone(AXLAPIBindingStub.java:11441) at com.britek.ucm.realtime.GetPhoneAttributesV4.getSinglePhone(GetPhoneAttributesV4.java:65) at com.britek.ucm.realtime.GetPhoneAttributesV4.main(GetPhoneAttributesV4.java:41) {http://xml.apache.org/axis/}hostname:britek-hplp org.xml.sax.SAXException: Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone - commonProfileName at org.apache.axis.AxisFault.makeFault(AxisFault.java:101) at org.apache.axis.client.Call.invoke(Call.java:2470) at org.apache.axis.client.Call.invoke(Call.java:2366) at org.apache.axis.client.Call.invoke(Call.java:1812) at com.cisco.www.AXLAPIService.AXLAPIBindingStub.getPhone(AXLAPIBindingStub.java:11441) at com.britek.ucm.realtime.GetPhoneAttributesV4.getSinglePhone(GetPhoneAttributesV4.java:65) at com.britek.ucm.realtime.GetPhoneAttributesV4.main(GetPhoneAttributesV4.java:41) Caused by: org.xml.sax.SAXException: Invalid element in com.cisco.www.AXL.API._1_0.XIPPhone - commonProfileName at org.apache.axis.encoding.ser.BeanDeserializer.onStartChild(BeanDeserializer.java:258) at org.apache.axis.encoding.DeserializationContext.startElement(DeserializationContext.java:1035) at org.apache.axis.message.SAX2EventRecorder.replay(SAX2EventRecorder.java:165) at org.apache.axis.message.MessageElement.publishToHandler(MessageElement.java:1141) at org.apache.axis.message.RPCElement.deserialize(RPCElement.java:236) at org.apache.axis.message.RPCElement.getParams(RPCElement.java:384) at org.apache.axis.client.Call.invoke(Call.java:2467) ... 5 more
