Subject: RE: Need explanation of a MakeTransfer element Replied by: Hemal Mehta on 29-09-2010 02:09:38 PM The application transfer element is similar to <goto next=" "/> element in vxml while the transfer refers to any external transfer using vxml <transfer/> element. This document was generated from CDN thread
Created by: Igor Zatsarevnyy on 29-09-2010 01:10:45 PM Hi, Does anybody know where I can find reference info regarding a MakeTransfer element presented in CVP Call Studio? In particular, what difference is between a Transfer element and MakeTransfer element? I attempted to search the whole Cisco site including forums but no luck. We are using CVP 7.0(2). Thanks. Igor
Subject: RE: Need explanation of a MakeTransfer element Replied by: Seth Katzman on 29-09-2010 01:29:26 PM
Thanks.
Igor
Hi Igor, I couldn't find any reference to a "MakeTransfer" element. There are two 'transfer' stock elements available in standard Call Studio that I could find: * Transfer element - The Transfer voice element performs a call transfer to a phone number specified by a configuration setting. Dependingon how the voice browser is configured, the call transfer can be a bridge transfer or a blind transfer. * Application Transfer element - A 'call' is transferred from one VXML application to another. When an application transfer occurs, the call ends in one application and begins in another. This differs from subdialogs (Subdialog invocation/VXML insert) where the application call doesn't end until the result goes back up to the parent subdialog.
Subject: RE: Need explanation of a MakeTransfer element Replied by: Igor Zatsarevnyy on 29-09-2010 02:03:16 PM Hi Seth, Thanks for your info. I can see the MakeTransfer element in the Call Control folder of the Elements panel in CVP Call Studio. Can you see that element in this place? Thanks. Igor
Subject: RE: Need explanation of a MakeTransfer element Replied by: Igor Zatsarevnyy on 29-09-2010 03:25:13 PM
Hi Hemal, I mean the call transfer elements (Transfer and MakeTransfer) but not the Application Transfer element. Or, maybe, I understood you incorrectly? Thanks. Igor.
Subject: RE: Need explanation of a MakeTransfer element Replied by: Igor Zatsarevnyy on 29-09-2010 04:27:28 PM Closed. It appeared our programmer have created own Transfer element with the name MakeTransfer. Sorry for the inconvenience. Thank you all for your time. Igor.
Subject: RE: Need explanation of a MakeTransfer element Replied by: Hemal Mehta on 29-09-2010 09:21:09 PM As indicated what you probably had was one element is Transfer and the other one probably simulating the <goto/> element used in vxml which merely transfers to another element, form etc. Not sure how exactly the maketRansfer element was defined.
