This document was generated from CDN thread
Created by: David Roberts on 06-01-2010 11:42:47 PM
I have a lab environment with a 2801 voice gateway with an E1 card and CM 7.13 connected to it via MGCP PRI. I view RTMT and see the callsactive counters increment up to the max of 10 channels (how it was configured) and then additional attempts do not appear to increment the OutboundbusyAttempts counter as I would have expected.
The CDR cause codes do correctly say 'no circuit/channel available' as I would expect.
Is this a bug?
Subject: RE: Outboundbusy attempts not working for E1
Replied by: Anitha V on 10-02-2010 06:42:25 AM
Hi David,
Could you please share the corresponding logs for this issue?
Anitha
Replied by: David Roberts on 11-02-2010 02:52:48 PM
Can you tell me which logs specifically?
Replied by: Anitha V on 22-02-2010 10:39:22 AM
Hi David,
Kindly send me, the CDR files in question and the corresponded CCM SDL / SDI logs.
Thanks and Regards,
Anitha
