cdnadmin
Community Member
This document was generated from CDN thread
Created by: Tore Skancke on 13-05-2011 05:26:10 AM
Hi.
Can someone help me make a LUA script which removes the "Asserted Identity" field in the SIP header for inbound calls to a CUCM 8 SIP trunk?
Thanks.
Best reg,
Tore S
Subject: RE: Remove "Asserted Identity" from SIP header using LUA
Replied by: Yossi Ben Hagai on 27-07-2011 03:06:30 PM
The following code should do what you've requested:
M = {}
function M.inbound_INVITE(msg)
    msg:removeHeader("P-Asserted-Identity")
end
return M
Yossi.
Replied by: Yossi Ben Hagai on 27-07-2011 03:07:32 PM
Hi.
Thanks.
Best reg,
Tore S
The following code should do what you have requested:
M = {}
end
return M
Replied by: Tore Skancke on 08-08-2011 04:46:43 AM
I figured it out myself, but thanks a lot for answeringYossi!
Thumbs up for you
Best reg,
Tore
