This document was generated from CDN thread
Created by: Michael Nelson on 08-02-2013 05:28:58 PM
In the participantsInCurrentMeeting element there is the numScreens field and the requiredCapacity field. What is the difference between the two fields?
Subject: RE: What is the difference between numScreens and requiredCapacity
Replied by: John Yontz on 08-02-2013 07:44:56 PM
Hi Mike,
Up through CTX 1.2, here is what you can expect: For the TS 8710 and MSE 8510 bridge resources, the values of num screens and required capacity will be the same. For the CTMS, the required capacity will always be one more than the number of screens because of the 30 FPS presentation data.
In later releases, the required capacity will likely have different unit representations driven by new TS capabilities.
- John
