cdnadmin
Level 11
Level 11
This document was generated from CDN thread
Created by: Andreas Muenstermann on 29-01-2009 12:13:14 PM
Hi *,
the Speaker of a Cisco 7911 or 7912 telephone can only be activated by using the Softkey "Speaker". Now we have the following problem: When the call is active (offHook) we send a Cisco XML Service window with new SoftKeys to that phone. Within that window the user should further have the possibility to activate the speaker.
Is there any URL that can activate the Spekaer like "SoftKey:Speaker"?
Best regards,
Andreas
Subject: Re: activate Speaker on Cisco 7911/7912
Replied by: David Staudt on 29-01-2009 02:34:38 PM
There is this URI:
Key:Speaker
Note that this button is a toggle, so it's not possible to select speaker=on or speaker=off. If the call happens to already be on the speaker, and Key:Speaker is used, the call will get hung up.
Subject: RE: Re: activate Speaker on Cisco 7911/7912
Replied by: AMAIA LESTA on 07-09-2009 04:21:29 PM
Dear Padawan
Please, could you tell me step-by-step where/how I can set this URI 'Key:Speaker'  in the CCM configuration in order to be accesible by the 7911 phones in my system?
Thanks in advance for your kind help.
